G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: nose on May 23, 2007, 10:48:08 AM
Title: z axis keeps moving up and down!! please help
Post by: nose on May 23, 2007, 10:48:08 AM
im new to the whole cnc and mach 3 thing just got imersed into it for the last 3 weeks and have learned quite a bit but still suck!
that having been said i did a drawing in corel and saved it as a cad file then loaded it into lazycam to clean it up a bit and then to post seemed all was well but when i run the g-code in certain parts of the code the z axis just keeps moving up and down :-[ heres the files i hope you guys can help thank you for your time!
Title: Re: z axis keeps moving up and down!! please help
Post by: Chip on May 23, 2007, 08:13:50 PM
Hi, Nose
Download LC now I think it's fixed give it a try, Was going to post this eariler got sidetracked.
LazyCam is posting an incorrect G0 Z Move's It's set to Z 60.000 hear, It's a Bug.
You can Edit it out in your Tap File in Mach, Edit then in Editor, Edit, Find "G0 Z", change the value to your desired G0 Z value (such as Z0.0000 or a safe Hight of Z0.1000 would be .1 units above your Z0 top of cut surface).
Thanks, Chip
