G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Samrai on July 20, 2016, 08:05:50 PM
Hi all,
I'm using Mach3 of Version R3.043.066. OS is Windows 7 or XP..
There is a problem.
After G31 probing action, Mach3 dwells for nearly 2 seconds unexpectedly.
To say concretely,
G31 Y150 F1000 (Metric)
Then, if a probe signal came at Y coordinate 110 mm, the motor stops immediately.
That's of course OK.
But the problem is the next action.
For example, the next command is to back..
G01 Y10 F10000
The motor doesn’t start immediately and starts nearly after 2 seconds.
Too slow!!
Do I need some configuration setting?
I will appreciate your help with this situation.
I'm using a breakout board named WiXHC.
Recently its driver was updated, then the problem has been almost solved.
Thank you, folks,
