Mach Discussion => General Mach Discussion => Topic started by: danielbriggs on June 22, 2016, 06:46:56 PM
Title: 3x Parallel Ports with Mach3 (ESS)
Post by: danielbriggs on June 22, 2016, 06:46:56 PM
Hi there,
The Ethernet Smoothstepper has 3x Parallel ports, and I need to interface all three for I/O with Mach3; I don't think I can fit it on 2x Parallel ports.
I've connected ports 1 and 2 to the PMDX-126, and the third to an additional PMDX I/O board.
How do I setup the extra (3rd) parallel port in Mach3?
Many thanks in advance,
Post by: Fastest1 on June 23, 2016, 07:53:57 AM
I believe you need the ribbon cable for the ESS and another BOB to tie into.
Sent from my iPhone using Tapatalk
Title: Re: 3x Parallel Ports with Mach3 (ESS)
Post by: robertspark on June 23, 2016, 12:24:33 PM
It is setup in the plugin, you need to go to the warp9 website and work through the information there, as basically all functionality comes through the plugin which means some of the stuff on the mach3 setup screens is redundant as it is only functional for the parallel ports
Stuff like backlash on the mach3 config screen, pulse width settings on the motor tuning page, and the check boxes for port1 and port2 on the ports and pins page have no effect.
Rob
