G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: W.Jansen on May 23, 2007, 02:02:56 AM
Hi Brian
Just a litle report.
If i select ZOOM BOX on the right side of the screen and i hit with the left mouse button one's , a point on the screen (without moving the mouse) my image is disappeared.
Greetings:
W.Jansen
Hi
Hold down the left mouse button and drag across the part you want to zoom in.That should work
Hi Klmark
Yes i know thats how to do it but i meant if i forgot to drag and just release the mouse button then my object is gone.
Thats a big punish for such a smal mistake.
Greetings:
Willem
Hi
Because it is zoom in so big you think it is but it ant Just double click the left mouse it will bring it back to orig seize
Ah why did i not think of that.
Thanks Klmark.
Greetings:
Willem
sounds like it is all fixed ;)
Hi Brian
Yes the problem is solved but it would be nice if a minimum size of the zoombox is required to activate the action.
Greetings:
Willem
