Mach Discussion => General Mach Discussion => Topic started by: macona on June 15, 2016, 02:42:32 PM
I am putting together a system using a couple linear motor slides with Parker ViX-250IH servo drives. The drives have an internal homing routine that handles everything. I can trigger it from an input or let it home itself at startup.
Can I make Mach just send a signal out to start the homing routine and then watch for the home good signal from the drives?
Yes, it is the way I have done it for years on my Beaver mill and Computurn Lathe, send a signal from Mach and the drives do Index homing and then tell Mach it has homed.
How do I set this up?
Make sure you do not have Home switches enabled in Ports and Pins as you do not need them when homing externally.
Next Operator menu then Edit Button Script and then click on the flashing RefAll button.
In the editor you will need to enter the VB suitable for what you want to do. As an example here is what I have on the lathe, I am using my PLC to send and accept the signals from the servo so the I/O is via Modbus but you could just quite as easily use general I/O in ports and pins and alter the VB accordingly.
Do
Call SetModOutput (21,1) 'Activate ModOutPut 20
If GetInput(19) Then Exit Do 'Loop until ModInPut 18 is seen
Sleep (10)
Loop
End If
Call SetModOutPut (21,0) 'DeActivate ModOutPut 20
DoOemButton (1024) 'Set Z axis Home
Do
Call SetModOutPut (20,1)
If GetInput(18) Then Exit Do
Sleep (10)
Loop
End If
Call SetModOutPut (20,0)
DoOemButton (1022)
Thanks, I will give it a try. These drives basically have a PLC built in so I can just program to watch for a home signal to run that routine.
Pretty neat little motors, 10nm resolution.
Yes most drives that can do Index homing have basic PLC capability.
