Mach Discussion => General Mach Discussion => Topic started by: Cbyrdtopper on June 01, 2016, 08:49:47 AM
Title: Spindle S Command Not Working
Post by: Cbyrdtopper on June 01, 2016, 08:49:47 AM
Working on a VMC and my spindle won't change speed using the "S" command.  The only way I can get the spindle to change speed is to manually enter a speed into the spindle speed DRO.  I have even tried writing a G Code program that varies the spindle speed and it still has no effect.  My spindle works great M3, M4, and M5 all work correctly and the spindle is calibrated, the only issue is the S command in MDI or G Code.
Any thoughts?
-Chad
Title: Re: Spindle S Command Not Working
Post by: Cbyrdtopper on June 01, 2016, 01:46:31 PM
Okay, problem is fixed.  I was running Mach3 R3.043.066 and switched it to R3.043.062 and everything is working just fine!! =)
-Chad
