Mach Discussion => General Mach Discussion => Topic started by: dmills102 on May 10, 2016, 05:05:04 PM
I built a cnc router using nema 23 270oz. steppers and the tb6560 board. I can jog both x and z axis at slow speed but the y axis just vibrates. I even replaced the tb6560 with a new one and the problem is still there. All the axis will move at high speed including the y axis, but it will not jog at low speed. I've tried about every setting there is with no luck. I'm not using micro steps.
Try swapping the cable from the x to the y. Just one end of the cable, this will verify the y motor is good.
I've tried that, the other axis becomes the problem
those boards are known to be not so good, look up on cnczone all bad storys
Thanks, I'll do that. I was thinking of going with a different system anyhow.
good idea
Your problem will be mid-band resonance. It occurs at low speed in the range of 2-6rps. You can hear the motors growl and change pitch when it is occuring.
What you need to do is buy a decent stepper drive such as the Gecko G540 4-axis stepper system that I sell. You won't look back.
http://www.homanndesigns.com/index.php?main_page=index&manufacturers_id=5
Cheers,
Peter
