Mach Discussion => General Mach Discussion => Topic started by: Exhibitology on May 08, 2016, 08:58:03 AM
I'm in the home stretch of lobotomizing a Multicam MG208 cnc router
with Mach3.
I've inserted a CSMIOIPS from CS-Labs in place of a Multicam M24
motion controller. It is driving stepper motors.
She homes. She moves. She cuts. She makes shavings.
However, she consistently loses her machine coordinates.
When I hit Reset twice, once to stop and once to restart, the green
borders haloing the axis buttons to the right of Reference All
turn off and I cannot jog with the soft limits.
This also happens is the machine sits unattended for more than
5 minutes.
What simple setting am I overlooking that is creating this issue.
Any insight is greatly appreciated.
Rich
Why are you hitting RESET???????????? To start and stop what?
The boarders around the axis`s tell you the machine has been referenced. If they go away or turn off, that means in that cycle of things....like after a RESET...... it no longer knows where they reff point is. Which also means that soft limits will not work either.
