Third party software and hardware support forums. => Promote and discuss your product => Topic started by: Weerasak on April 28, 2016, 10:21:42 AM
Title: MB2 Bob for ESS
Post by: Weerasak on April 28, 2016, 10:21:42 AM
The MB2 is an Industrial environment BOB, featuring: 6 Axis Line driver; I/O that utilizes all 3 ports of the ESS; OSSD safety output; Status LEDs for all signals; Requires a single 24V power supply.
Specification and Features:
-With ESS, Ethernet connection helps controller and drives located away from PC and has more noise resistant than USB and parallel port connection.
-Run on Mach3 / Mach4 with Windows XP, Win7, Win8 both 32 and 64 bit, on both desktop and notebook computers.
-New! Utilizes All 3 ports of ESS.
-New! Motion command signal can be selected between Pulse/Sign, CW/CCW, Quadrature. Frequency can be selected from 32 KHz to 4 MHz.
-New! Differential line driver for motion signals, makes a longer wiring with more resistant to interference when comparing to TTL open end.
-New! Single 24Vdc Power supply is needed. On the board consist of  5Vdc isolate and non-isolate dc2dc converter, thus saving installation space and wiring.
-And more...
Product Link.
http://www.cncroom.com/index.php?main_page=product_info&cPath=7&products_id=209&language=en
(http://i389.photobucket.com/albums/oo335/vrasak/ESS-MB%20Small_zps3dwitklo.jpg)
Title: Re: MB2 Bob for ESS
Post by: Weerasak on August 23, 2016, 11:25:29 AM
here is correct link to Ethernet smoothstepper breakout board
http://www.cncroom.com/interface-break-out-board-mach3-mach4/smooth-stepper-ess-mb2
Title: MB3 the third generation
Post by: Weerasak on April 27, 2019, 07:56:16 PM
Here is the new third generation of MB series board. The MB3, it keeps the best features of its predecessors MB1 and MB2 and in addition, allows all isolated inputs be used in both NPN or PNP mode and also to operate with either 5V or 24V. In this new design, the ESS board can be directly plugged into the MB3 without using ribbon cables. This makes the ESS easier to install and reduces the distance the signals must travel. It eliminates a number of contact points, as well as inductance and resistance between the ESS and MB3 board.
https://www.cncroom.com/interface-cards/ess-mb3
https://www.cncroom.com/interface-cards/mb3
(https://www.cncroom.com/images/MB3TopPanel5.jpg)  (https://www.cncroom.com/images/ESS-MB3_.jpg)
https://www.youtube.com/v/pGaCyydRLCw
