Mach Discussion => General Mach Discussion => Topic started by: tlittler on April 12, 2016, 07:43:35 PM
what program can I use to layout my own text and design for making signs? how do I convert this file to a format to be run on the Mach 3 software?
Thank You
Tim
Take a look at Vectric software http://www.vectric.com/
It is not free but it is easy to learn / use, has suitable Mach3/Mach4 post processors (which create the Gcode) and has 'try before you buy' demo versions just like Mach.
Hi I have never used this bet here you go.
http://www.scorchworks.com/Fengrave/fengrave.html
I used to work in digital prepress. I worked with all the Adobe products. Say I did a layout in Adobe Indesign is there a converter to G code.
In short, no, you will save the artwork in a format compatible with the CAM software of your choice and generate the code with CAM.
