G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: Chip on May 17, 2007, 03:34:35 PM
Hi, Art & Brian
LC is working nice:
Origin Mouse move is working hear just fine now, No Crashes So-Fare !.
Hears a couple of little Issue, Just to keep you from getting Board.
Ruffing Cut to Long.
Right Arc differs from Left Arc, The last picture. is correct Now.
Going to be Au-Some, Thanks, Chip
Lathe will get a BIG update after we are done with mill and plasma :)
Chip can you post your .lcam file please
Hi, Wnevels
It's right below the first picture, second Red Download Button.
Thanks Chip
Hmm ok i was looking for the .lcam file to see what settings you are using
I loaded that .dxf file and when i get to mach its excatly opposite of what i see on yours.
Hi, Wnevels
Hear you go wasn't paying attention hear, I think this is it.
Thanks Chip
Chip thanks for the .tap file
whew i finally got Lcam turn to work, its really cool once you get it.
thanks
anybody know how to fix the void in the face arc?
Hi, Wnevels
It's your tool spec's/cutter that limits the cut path, You'll need a tool change to get in there.
It would require a different tool and a different layer to cut it, left or right with a appropriate back angle setting than what your using now.
Post your DXF file, You can cut it out as it is then create a second file to do the curve cut with a different tool.
Don't think LC lathe is to that point rite now.
Hope this Helps, Chip
Chip thanks for the reply. I'd tried everything i could think of just looking for a confirmation that it was time to start coding by hand.
Now i'm off to play will Lcam mill and offsets.
Wes
