Mach Discussion => Mach4 General Discussion => Topic started by: labjac on March 26, 2016, 03:29:54 AM
Hallo
I purchased both the parallel license and the Mach 4 licensing, all licensing installed and no messages showing licensing issues.
I created a new milling profile, In the Driver I can select the parrallel port which is all setup as per the video, but when selecting plugin the list is empty.
Any advise?
Jacques.
You have to copy the files from the "parallel port" Plugin in to the plugin folder.
If you made default installation the folder is located here: "C:\Mach4Hobby\Plugins"
Best regards,
Gerhard
Hallo Gerhard
Thanks, yes thanks, I copied the three files to the profile and all up and running now.
Thanks for the assistance.
Best Regards,
Jacques
