Mach Discussion => General Mach Discussion => Topic started by: william55 on February 14, 2016, 01:57:20 PM
Title: Mach3 homing and limits
Post by: william55 on February 14, 2016, 01:57:20 PM
Hi
Just finished tuning my motors and setting up my homing and limits, works well. I ran the road runner sample no spindle or tool and my Z stays up through  the program and hits my limit switch half way thru, I assume because it has a raise Z g code. do I have something entered backwards for the Z command or do I need to zero the Z at a material height before starting.
Thanks Bill
Title: Re: Mach3 homing and limits
Post by: Overloaded on February 14, 2016, 04:47:44 PM
............. do I need to zero the Z at a material height before starting.
Yes.
The surface of the material is typically Z0 in program coordinates.
Post by: william55 on February 15, 2016, 01:08:36 PM
Hi
Do I enter a Z0 in the g code before I run the roadrunner
Thanks Bill
Post by: Overloaded on February 15, 2016, 02:17:28 PM
No, you don't enter anything into the GCode.
Jog your Z axis down to the surface of the material, then enter 0 into the Z Axis DRO.
That will establish the proper relationship between the GCode and the actual material being machined.
Post by: william55 on February 15, 2016, 02:39:06 PM
Thanks will try
Bill
