Mach Discussion => General Mach Discussion => Topic started by: james elder on May 14, 2007, 10:55:08 AM
an hour into a job I hear something isn't right. a problem has developed on the X axis, where it is losing 5mm at a time, going x+, and a few mm x-. I have dissassembled down to the motor itself, and the problem is still evident - hand held the motor will tug tug tug twich twitch twitch as it turns, rough, like a missing car engine, instead of a nice sweet whine, unless I ask for some rapid movement, when as it reaches higher speeds, it becomes smooth.
Classic symptoms of.....?
Thanks in advance.
Jim
Hey James,
What kind of drives are you using? Do they have any tuning provisions? At what speeds do they run good and bad? Is this a new problem or a new set up?
Hi Chaoticone.
They've been running fine, it's a new problem, developed mid-job. They are all tuned nicely, and I checked that nothing had got altered in the motor tuning.
I dunno what the drives are, i'll try & see
Jim
Ah Gekko's.
Any ideas?
Jim
Jim,
I have sent you a pearsonal message.
Hi all
Well, the new motor does the same, do I guess it's not that.
What's the next step?
Nothing changed, it went rough mid job. What could alter and cause this problem?
Jim
Swap over a drive and see if the problem moves with it.
Thnks Hood, will do. All terminals or 1 through 6 or what? (they are a way apart)
Also noticed the X power on light dims well before the others after power off....
Jim
If your cables will reach from one drive to another just swap over the complete plugs but if they dont then unscrew the suspect drive and move it over and connect in the other drives plugs.
:-[ Oh yeah. That was easy.
The problem follows the gecko
So this means....?
Jim
You need a new Gecko :( contact Mariss, he might be able to repair it for you.
Not :( but :). You've found the problem for me thanks.
No UK supplier then?
Did you say about £80 Shipped from the States? But compared to the £175 i shelled out for the MAE 300 3438 430 a8, the other day....anyone interested? No it was sale or return, thanks Cetronic, so it's cost me a few quid to confirm it wasn't the motor.
You don't have a spare Gekko anyone? I was halfway through this urgent job, as always....
Thanks again Hood.
James are you in the UK? If yes PM me your address and I will lend you a G201 until you get another or yours repaired.
How did you get on?
All running again, just like before. Thanks for the diagnostic help,thanks for the loan of the Gecko, it's really helped me complete this urgent job, and I'll get it or one back to you asap.
Jim
No problem, glad its working. Was just ready to kick some arse at the post office if it hadnt arrived LOL
