Mach Discussion => VB and the development of wizards => Topic started by: leversole on January 25, 2016, 10:21:17 PM
I have the following attached to a button...code seems like it should work, i created two dros, OEM1300 and OEM1302, get a data type mismatch. When I step thru with the debugger, I am getting the correct values into XPos and YPos...can't figure what I am doing wrong..
Sub Main
XPos=GetOEMDRO(1300)
YPos=GetOEMDRO(1302)
Code "G0 X" + XPos + "Y" + YPos
End Sub
Try this
Code "G0 X" & XPos & "Y" & YPos
Ah the stupid overloading of the + op in VB and the like.
Here's the official word from MS
Differences Between the Two Concatenation Operators
The + Operator (Visual Basic) has the primary purpose of adding two numbers. However, it can also concatenate numeric operands with string operands. The + operator has a complex set of rules that determine whether to add, concatenate, signal a compiler error, or throw a run-time InvalidCastException exception.
The & Operator (Visual Basic) is defined only for String operands, and it always widens its operands to String, regardless of the setting of Option Strict. The & operator is recommended for string concatenation because it is defined exclusively for strings and reduces your chances of generating an unintended conversion.
Here's what that actually means:
Look - we screwed up - ok?. We made TWO concat operators because we're dumb. Worse we made one that works always and one that sometimes doesn't. Just use the & ok.
Thanks! I should have known that from my previous programming experience!
