Mach Discussion => General Mach Discussion => Topic started by: MitchB on January 17, 2016, 12:15:29 PM
Title: Manual tool change with Mill Wizard and Mach 4
Post by: MitchB on January 17, 2016, 12:15:29 PM
How do I get the machine to stop for a manual tool change after using G code generated by Mill Wizard (e.g. for two lines of holes using two tools)
Title: Re: Manual tool change with Mill Wizard and Mach 4
Post by: MitchB on January 17, 2016, 12:25:48 PM
I see now that I use the M6 macro.
Post by: MitchB on January 17, 2016, 12:53:48 PM
Not that simple, I guess.  I put the M6.mcs from the default Mach profile into the Macros directory of the profile I am using, but it looks like it isn't called.  Is there anything else I need to do?
Post by: Hood on January 17, 2016, 01:23:44 PM
Config menu then General Config, there is an option there to stop spindle and wait for cycle start.
Post by: MitchB on January 17, 2016, 01:39:09 PM
Not in Mach 4
Post by: Hood on January 17, 2016, 01:41:17 PM
Ah ok never noticed the title but then again why post here rather than the Mach4 section?
Post by: MitchB on January 17, 2016, 02:23:07 PM
I originally thought this was related to Mill Wizard, but now that I realize it's the way Mach 4 handles M6, you're right - I should post it there.
