Support => Downloads => Post Processors => Topic started by: StevenSeim on January 14, 2016, 11:38:37 PM
Hello folks and good day.
I am looking for a MACH 3 (and/or 4) post processor for MasterCam version 8.
Does such a file exist? If one does not, is there an existing v8 post process compatible with MACH, say MPFAN?
Please let me know. Mail me direct at sseim@comcast.net as/if appropriate.
Many thanks!
Hi
I am new at this forum and cnc stuff, You can find what you are looking for at
http://www.machsupport.com/wp-content/uploads/2013/04/Mastercam_mach3b.zip
I also have a problem with my post processor, I use mastercam X9 with MACH3 post
but I get this error msg when I post the G code.
26 Jan 2016 01:16:08 PM - Report created.
26 Jan 2016 01:16:08 PM - Initialize posting log file
26 Jan 2016 01:16:08 PM - Using MP run version 18.00 and post components version 18.00
26 Jan 2016 01:16:08 PM - Initiate opening the post processor file(s).
26 Jan 2016 01:16:08 PM - C:\USERS\PUBLIC\DOCUMENTS\SHARED MCAMX9\ROUTER\POSTS\MASTERCAM_MACH3B.PST
26 Jan 2016 01:16:08 PM - The post processor file has been successfully opened.
26 Jan 2016 01:16:08 PM - Post version information (input):
26 Jan 2016 01:16:08 PM - UPDATEPOST Version 18. was used to modify this file.
26 Jan 2016 01:16:08 PM - The file was modified by this product on 26 Jan 2016 09:15:18
26 Jan 2016 01:16:08 PM - The post was written to run with Mastercam Version 18.
26 Jan 2016 01:16:08 PM - The post product type is Router.
26 Jan 2016 01:16:08 PM - Initialization of pre-defined post variables, strings, postblocks was successful.
26 Jan 2016 01:16:08 PM - Search for defined post variables, strings, postblocks was successful.
26 Jan 2016 01:16:16 PM - PST LINE (2653) - The formula/boolean failed (general message) <----------------------------------------- Problem ?????
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'ltol$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'met_ltol$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'maxrad$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'atol$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'error_msg$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'err_file$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'maxnccomment$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'dec_seq_left$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'tplanemode$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'breakarcs$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'breakarcsxz$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'breakarcsyz$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'lbreakarcs$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'lbreakarcsxz$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'lbreakarcsyz$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'helix_arc$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'lhelix_arc$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'do_full_arc$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'do_full_arcxz$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'do_full_arcyz$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'ldo_full_arc$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'ldo_full_arcxz$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'ldo_full_arcyz$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'arccheck$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'larccheck$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'rotfeed4$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'rotfeed5$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'lrotfeed4$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'lrotfeed5$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - CONTROL DEFINITION - Post variable 'peckacel$' was re-initialized from 0. to 0.
26 Jan 2016 01:16:16 PM - Successful completion of posting process!
I dont know what to do!! maybe someone can show me in the right direction ??
any help would be appreciated.
Thank you Paul. I'll load this up and test for myself.
Is the part you intend to cut 2 1/2 or 3D?
pleasure Steven
well this error seems to pop up regardless what type of machining I am doing?? It must be something in the POST CODE that is not right
