Mach Discussion => VB and the development of wizards => Topic started by: tantan on January 13, 2016, 12:15:19 PM
i need to detect a falling edge of an input to control my turret
i think the code is right but it hangs mach3?
wanted_position = 6
counter = 0
marker = 0
'input 1 = the couter of the turretpostion
message "c = " &counter
sleep(100)
activatesignal(output3) 'start run turret
While ismoving()
Wend
While (counter <> wanted_position)
If Not isactive(input1) And marker = 0 Then
counter = counter + 1
marker = 1
End If
If isactive(intput1) And marker = 1 Then
marker = 0
End If
Wend
deactivatesignal(output3) 'stop turret
tnx for your reply!
OK what do you mean by it hangs Mach3 ?? Have you single stepped through the code to see what line causes it to hang ?
hi,
the counter does not count up futher than 1. then the while loop hangs mach3 because the counter never reaches 6.
i did use the right input, i did checked that
tnx tantan
If you single step down through the code you will see the problem as to WHY you are stuck in an endless loop with no way out(;-)
The first loop sets specific conditions after that the escape conditions do not exist as I see it from here so around and around you go.
The counter can NEVER count up past teh first loop because teh count incrementing is in the wrong position inside teh loop. As teh condition is not met it hops over teh counting code .
can you see Input1 changing signal in diagnostic Screen ?
While is moving
Wend
is useless because no 'real' axis is moving.
TPS
Ismoving() does not only pertain to motion it is about any time that mach3 is doing something internally such as uipdating a dro writing something to mem ,etc
hi
yes the input changes in the diagnostic screen. i hope the frequency of the inputsignal is not to high for this basic code. i will test it tomorrow with a manual switch,
as far as i can see the code should detect an edge...
tnx for your replies.
hi,
it works,
mach does not read inputs within a while loop.
https://youtu.be/39QgfGTrPZo (https://youtu.be/39QgfGTrPZo)
I do not think that is true "" mach does not read inputs within a while loop. "" Can you give me an example of where you that is true ???
see code i posted in my first post. that did not see input1 changing.
i call a sub in the while loop that reads the input. that works.
tnx
Look again at the code in your first post. The reason it doesn't read the input (in the second if) is simply down to a typo.
I have used while and do loops for years to wait on an input signal. I have never seen one programmed correctly that did not work in Mach3.
