Mach Discussion => Brains Development => Topic started by: Davek0974 on January 12, 2016, 12:24:00 PM
I have a #var being set to 1 or 0 via G-code.
I have a brain that switches an output IF two conditions are met -
The #var being = 1 AND the RUN(804) LED being on i.e. we are running code.
However the logic fails as the output is triggered when I load a g-code file OR when doing a path regeneration.
Any reason why this should fail and is there a way to make it work??
Check your other post on this I posted a new brain to try.
Ok, thanks, got it.
