Mach Discussion => General Mach Discussion => Topic started by: dwrightny2266 on December 31, 2015, 08:55:47 AM
Title: Strange Axis movement
Post by: dwrightny2266 on December 31, 2015, 08:55:47 AM
Setting up a new controller, and i noticed that all axis don't return to the same position that the left from.  For example
Starting at 0
G0
X 5"
X-5" (expecting to be at 0)
But ending at -2" on both x and y axis.
Any ideas?
Title: Re: Strange Axis movement
Post by: ger21 on December 31, 2015, 09:13:50 AM
Are you sure that you're in incremental mode?
When you do X 5, does it go to 5?
Either your steps/unit is wrong, or you're losing steps.
Post by: dwrightny2266 on December 31, 2015, 09:21:29 AM
It will move out in one direction 5" but return in a different measurement.
In the General Logic Config Panel, the distance mode is Absolute, and IJ in Inc.
Need to learn more about it. Still in learning mode lol
Post by: ger21 on December 31, 2015, 09:24:20 AM
In Absolute mode, this should end up at -5, moving 10"
Post by: dwrightny2266 on December 31, 2015, 09:36:07 AM
 Should I normally be in Abs or inc mode or is that not a simple question to answer?
Post by: dwrightny2266 on December 31, 2015, 09:47:30 AM
Spending some time watching some videos and researching this more.
Thank you for your help :)
Post by: ger21 on December 31, 2015, 09:48:19 AM
Most people use absolute most of the time.
But each has their place.
Post by: dwrightny2266 on December 31, 2015, 10:01:01 AM
Like anything else, the more we know, the more we find that we don't know :)
Thanks again.
