Mach Discussion => Mach4 General Discussion => Topic started by: barnettch3 on December 17, 2015, 06:56:46 PM
Title: Motor counts per in
Post by: barnettch3 on December 17, 2015, 06:56:46 PM
I was wondering if there is anyone out there who would be able to shed some light on the formula for calculating the "count per in" when calibrating the motors.
I running a NEMA 34 but I'm at a little loss on the process. I'm using a chain drive with 14 tooth drive sprocket and a 20 tooth idle sprocket each with .25 pitch.
Really at a loss for whats next.
Thank you.
Title: Re: Motor counts per in
Post by: ger21 on December 17, 2015, 07:21:26 PM
If it's a fixed chain, the machine will travel 3.529548 inches per motor revolution, if the sprocket is mounted to the motor.
I used an online calculator to find the diameter of your sprocket, and multiplied by pi.
Post by: garyhlucas on December 17, 2015, 07:35:03 PM
I don't think this is going to work out with the pitch diameter because a chain sprocket is chordal, not round. So for one revolution the distance will be number of teeth times the pitch or 14 x 0.25 = 3.5" However chain does not run smoothly like a belt. It oscillates forward and backward. You can see this clearly on sprockets with a very small number of teeth and it can produce violent vibration.  You also can't tighten a chain up taught without causing tight and loose as the sprockets turn.
So chain is kind of a bad idea for linear motion, but if that is what you have my explanation of the math above will work.
