Mach Discussion => General Mach Discussion => Topic started by: AJA on December 14, 2015, 08:45:54 AM
Title: How to change an image into Mach 3 language
Post by: AJA on December 14, 2015, 08:45:54 AM
I have been asked to make a brand for a logo.  How do I change an image into a language that Mach 3 will accept?
This will be done on a vertical mill.
Any help is greatly appreciated.
AJ
Title: Re: How to change an image into Mach 3 language
Post by: ger21 on December 14, 2015, 08:46:42 AM
Load it into a CAD program and trace it. Then bring the tracing into a CAM program.
Post by: AJA on December 14, 2015, 02:39:24 PM
 My cad will only output a .dwg file.  How can I convert that g code?  Lazy cam does not work.
Post by: ger21 on December 14, 2015, 03:03:28 PM
Most other CAM programs can read a .dwg file.
Are you sure you can't save as a .dxf? Almost every CAD program can.
Post by: AJA on December 14, 2015, 03:37:51 PM
Lazy cam will not read any of the dxf file that I save the cad fill in?
Post by: ger21 on December 14, 2015, 05:26:52 PM
Save as the oldest version of .dxf file that you can, preferable v12 or older.
Post by: AJA on December 14, 2015, 05:37:39 PM
I've tried R12 asc II, R14 asc II, R2000-2004, R12,13, and 14 binary among others.
Any other ideas would be appreciated.
Title:
Post by: bwprice100 on December 16, 2015, 03:46:20 PM
As far as I know a dxf file is just a text file so open it in notepad and see if you can read it.
I hope this helps Brian
www.ebolt.co.uk
