General CNC Chat => Show"N"Tell ( What you have made with your CNC machine.) => Topic started by: Cncman2nv on December 06, 2015, 09:55:34 PM
Nearing Completion is a dual 5c spindle lathe. The main frame of the lathe was bought a cabin fever '09 from Ajax CNC in Pennsylvania. The rear spindle was created using a Allen Bradley servo motor and a 5C collect closer from grizzly tool you tube channel is cncadam
https://www.youtube.com/watch?v=xyirJ8cPgQo
thanks
Excellent work Adam. 8)
Thanks Tweakie... It Has been four years in the making lots of trial and error there is more work to be done but at least I'm at the 90% marker
Keep up the good work. Very impressive!!
Thanks Chrisjh... I couldn't have done it with out your great document on using the G52 Offsets so thank you! and Keep up the good work
Nice!! Could you give some insight on how you setup Mach3 to control dual spindles like this? I will be building a lathe very similar to this and need to be able to control dual servo driven spindles (step/dir stream for both spindles).
Thanks!
