Mach Discussion => General Mach Discussion => Topic started by: ChrisAttebery on November 27, 2015, 01:59:40 PM
Hello,
I recently reinstalled Mach3 on a new PC. When I did I set the text editor and pdf viewers incorrectly. Now i just get an error message when I try to edit gcode or open the manuals. How can i reset the text editor and pdf viewer to different tools?
Chris
You set the path of the g-code editor in general config.
I don't think that Mach3 has anything to do with a pdf viewer. Isn't it just the default Windows pdf viewer?
That was it. The pdf viewer is set in Mach Standard Mill. Thanks Ger!
