Mach Discussion => General Mach Discussion => Topic started by: desertland on November 16, 2015, 02:06:11 PM
OK this is one of those " should be simple" but for I have not figured out how to get the M11 command to work triggering a laser diode.
I do have it working with the M07 and M09 commands for the flood control. but flood control has enough delay to notice a deeper burn from the delay.
I also have the latest version of MACH3 that has the M11/M10 laser support.
I'm just doing simple on/off. The signal is connected to pin 17 of a break out board. The BOB is connected to PORT 3 of a smooth stepper. In the MACH3 plugin control I have port 3 enabled as an output.
Question one on the M command. As I understand it, in the G code the command has to look more like this: M11P1 So the "P" is that for a pin out, as in pin 17 from the BOB. So in my case it should read as M11P17 ? Or do they mean OUTPUT#1 ? from the ports and pins set up?
With the M10/M111 commands the 'P' relates to the Output # (not the pin number).
So M11P1 would switch on Output#1 (which in turn could be mapped to output pin 17) at the instant of an axis movement.
When using the Smooth Stepper configure the M10 /M11 commands in the SS plugin software.
With regards to the ESS, M11Px and M10Px .... the "x" part makes no difference....
they (the ESS) only has one output that is able to respond to M10 / M11 commands
And as Tweakie says... that is setup in the ESS Configuration Screen (about 1/2 way down the Right hand side).
You basically set the Output that you wish toggled when the M10 (off) and M11 (on) commands are seen in g-code.
So in your case ... on the ESS Congig Screen you would enter Output "3".
And every time an M11 / M10 code is seen it will instantly trigger / toggle output 3...
I use the command with torch height control and plasma cutting..... for me it is an easy way to toggle THC without hesitation via an M-code when I want to from within sheetcam.... for example when cutting curves of a certain radius of cutting circles etc. Normally if I'm cutting straight lines and the torch height controller is providing a "THC OK" signal my motion controller (ESS) will move the torch up and down whenever a "THCUp" or "THCDn" command is received (as I'm using a motion controller).... bu feeding the "THCOK" feed through a relay before the input pin.... I can break the "THCOn" signal on demand when I'm cutting corners without the machine slowing down / hesitating to execute THC m-codes....
It is a hack... but it works well!
Rob
Strange.. a "Rob" and another fellow responded to my post in less than an hour. For what ever reason there answers/posts seem to have been deleted.
Anyhow, thanks to them I'm laser burning with near instant M11 commands.
Yeah, I thought I responded to this one a while ago (yesterday?)
Rob
Rob
You did in fact...This was your post:
Message :
The ESS does support m10/m11...
You need to know what the programmed output number is for your current m07
Then go into the ESS config page and programme in the output number for m10/m11
Rob
