Mach Discussion => General Mach Discussion => Topic started by: D.Nischal on November 02, 2015, 05:26:08 AM
Title: Adding a Relay
Post by: D.Nischal on November 02, 2015, 05:26:08 AM
Hi all
I am new to this forum.I have a HY-TB4DV-S  control board with MACH 3 for my CNC machine. In that, spindle motor is controlled by a separate unit. Now i want to add a 12 V DC relay with this control board and like to control the relay using M03, M04 and M05. After modifying the pin, port numbers and motor output without connecting the relay i tried with M03.  Now i am getting a 'click' Sound which refers the relay is activated, but i didn't get  any voltage in M1  ,M2 and  Ground pins of my controller. [/b]So, please tell me what is the error and how to solve it. attached is the photo of my control board.
Title: Re: Adding a Relay
Post by: Overloaded on November 02, 2015, 07:53:29 AM
Looks like M1 and M2 might be just the NO contacts of the relay.
Check continuity between them when it clicks on/off.
The PWM and Gnd appear to be for a VFD.
Pic shown appears to be of a similar model.
Proceed w/caution.
Post by: D.Nischal on November 02, 2015, 10:28:39 AM
Thanx alot for your reply. Will try with this. Thanx again
Post by: D.Nischal on November 03, 2015, 05:56:48 AM
Yes. You are right. I Checked the  continuity between them when it clicks ON and OFF. Then i used a separate  DC power supply for  the relay. Its working now. Thanks a lot for the info. Attached is the pic of my relay connections.
Post by: Overloaded on November 03, 2015, 06:03:40 AM
Good job !
Russ
