Mach Discussion => General Mach Discussion => Topic started by: rusticalmond on September 27, 2015, 10:05:40 PM
I have completed most of my CNC build for cutting foam wings with a hot wire cutter. It would be great if I could get some help on the CNC G-Code software to run my cutter. Can Mac3 work for me? Also if so how do I set it up for 4 Axis to cut tapered wings. Currently I am using the demo version of Mac 3 to test my motors, CNC board, Motors, Motor Driver Boards. I require X , X1, Y, Y1
This is the link to my build on open builds org. It shows what my machine will look like.
http://www.openbuilds.com/builds/cnc-hot-wire-cutter-4-axis-for-cutting-foam-wings.2508/
I have yet to purchase the C-Beam Actuators that the motors will drive to run the wire.
