G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: Brian Barker on May 04, 2007, 02:56:49 PM
Title: Lcam 2.0...
Post by: Brian Barker on May 04, 2007, 02:56:49 PM
Hello,
Lcam Rev 2.0 is out and there is a video on line telling you a bit about how it works... you can't do Foam with this version (So if you need that please Do NOT Install Rev 2 at this time) . Please try this version and tell us what you think and I also think that you will find many things that you have asked for in this version :)
One known bug is that you can't do turn in Dia mode ... I have to do a bit more work in that section :( But Mill and plasma should be working...
Brian
Title: Re: Lcam 2.0...
Post by: klmark on May 04, 2007, 04:21:33 PM
Hi Brain and Art
 Before i tell you of a problem i have i want to Thank you guys for the hard work you do to make oures easier one thing I had to smile about is the OOOPS button you hit the nail on the head with that one  I have a problem if I want to change from the inside left or the outside right if I double click the lead in I get the LEAD CONFIGURATION box coming up if I change inside left to outside right or back and fort it dose not change on the tool path
                                                    THANK AGAIN
Post by: Chip on May 04, 2007, 04:27:05 PM
Hi, Art, Brian
The problem of moving origin with mouse is working fine with new Ver., Never could get it to work hear with Prev. Versions.
Let the Games Begin Thanks, Chip
PS: Left out the "WOW" !!!!! Wo---h---oo
Post by: klmark on May 04, 2007, 04:31:56 PM
Hi Brain
I did get the lead in and out problem working but i do not know what I did Differnt
Post by: Brian Barker on May 04, 2007, 09:26:33 PM
If you can find a way to break it every time we can fix it :)  I will keep an eye out for that problem..
Chip, I didn't tell anyone but there are a few more words in the posting word list. You and a few others are the only ones that have made posts for Lcam and I just wanted to tell you. I will be making a Doc for posting but it will be after we are done adding to it.
Have fun guys and keep telling us what you need
Brian
Post by: Chip on May 05, 2007, 02:55:37 AM
1. Duplicate. line in lower left Square is missed by old and new LC, with Remove Redundant lines Checked or Un-Checked, Load Options.
2. Dots are missed in Layer_3_ Dot, with Remove Dots Checked or Un-Checked Load Options, or with Layer Enabled Checker, Old ver Worked.
Jumped the gun hear Previous Post, "The problem of moving origin with mouse is working fine with new Ver., Never could get it to work hear with Prev. Versions".
3. What I find is If I load the Attached file and don't zoom in on the Origin Marker first and Move it, LC errors to Windows error report.
Once I've moved it and double click to default size window it seems to work fine from then on, Sofar.
I have the same version of Visual Studio you use, If I could get some partial source code, New or Old that covers this type of Origin move and  a little guidence from someone maybe we could track this problem down and be done with it.
I've reported this before with Debug of program with EXE file but its in Assembly code, Guess this is hard to work with,
I have the time and computer with this problem, Would like to help on this if you have a way, This problem is causing a few others problems also.
Another Great Advance In New LC, This is So-----Nice.
Thanks, Chip
Post by: DennisF on May 05, 2007, 11:36:18 AM
Hello Brian
Is this the version that has the fixes for turning where it post corectly for a lathe.
Rg's
Dennis
Post by: Brian Barker on May 05, 2007, 01:43:29 PM
it will work as long as you use Rad mode...
Post by: PaulWC on May 05, 2007, 09:03:22 PM
Hi Art and Brian,
Well... ya got my money today... gladly given. Great improvements. Remarkable what you guys can do with no sleep, and chatting on the net everyday!  ;D
The first thing I tried was Turn, since that is what I need the most... I have a couple of other MillCAM apps.
I can't seem to get g-code output. I read the thread on dxf prep, and tried the AOuterProfile.dxf sample. All the steps seem to go through, but no roughing or finish profiles are generated.
I did get one other dxf to work, but it was a non-conforming version. The g-code had some way out there values for "K"?
Here are my files and images for your spare time perusing.  ;)
Post by: PaulWC on May 05, 2007, 09:05:54 PM
Here's the rest...
Thanks, Paul, Central OR
Post by: PaulWC on May 05, 2007, 09:11:38 PM
Me again,
Just noticed the Width setting shows 0.0078. It is actually 0.078 in use. Brain F*rt when generating the screen caps.
Paul, Central OR
Post by: PaulWC on May 07, 2007, 11:53:52 AM
Just downloaded ver 2.00.2 and can now generate Turn profiles. However, the profiles are shifted to the left by the nose radius value, and there is a nose radius artifact at the right end of the profile. Also, the profile "spills over" the left end and goes almost to spindle center. The posted G-code has "K" values that are *extremely* high digits, and other X-Z values are out of range for the min-max boundries of the original dxf.
Attached are the latest rev of my dxf, screen shot of generated profile and G-code posting.
On the Mill side, I'm having issues with "hungapp" lockups when trying to set "drill circles".
Thanks for all the effort you guys are putting into this app. LC is maturing rapidly and is appreciated. Looking forward to future revs... kinda like opening the latest Birthday card from Grandma... can't wait to see what's stuffed inside.  ;)
Paul, Central OR
Post by: Chip on May 07, 2007, 12:33:34 PM
Hi, Brian
Missed your comment on Post options looking forward seeing the list, Thanks.
Items 1, 2 working now with 05 07 Update.
Item 3 still not working.
Working now 05-07 Update 1. Duplicate. line in lower left Square is missed by old and new LC, with Remove Redundant lines Checked or Un-Checked, Load Options.
Working now 05-07 Update 2. Dots are missed in Layer_3_ Dot, with Remove Dots Checked or Un-Checked Load Options, or with Layer Enabled Checker, Old ver Worked.
3. What I find is, If I load the Attached file and don't zoom in on the Origin Marker first and Move it, LC errors out to Windows error report.
Once I've moved it and double click to default size window it seems to work fine from then on, Iif I load a new file, I have to repeat the
Zoom, Mover Origin again. Un-less it the same file
Thanks, Chip
Post by: klmark on May 07, 2007, 01:27:33 PM
Hello Everyone
I have the same problem on one computer it works as afn09556 has posted but on  the other one no  matter what I do I always get a errors out to Windows error report just to let you know some other guys have a problem to has any one tryed the Mach 3 Load button In LC my dose nothing or less I am not doing something right  I am not complaning just testing
        markkl
Post by: klmark on May 07, 2007, 01:35:52 PM
Hi
Where can a guy download LC ver 2.00.2 I don't see it on the web
                                      thank you
Download the LazyCam in normal download, It's Been updated, Just doesn't show new Ver., Chip
Post by: Chip on May 07, 2007, 02:07:42 PM
Hi, Brian & Paul
Just downloaded Paul's NC file, It Crashes Mach3 to Windows error report.
Having the same problem with the LC Lathe G-code, The K values are huge, 1000K Billion's, Bigger than I can count.
N640 G1  X-5.0748
N645 G0  Z0.1000
N650 G1  Z-1.0000
N655 G3  X-5.1250  I-2.5625  k-6277438562204192500000000000000000000000000000000000000000000000000.0000
N660 G0
N665 G1
N670 G0  X0.0599  Z0.1000
N675  Z-1.0000
N680 G1
N685 G0
N690 G1  X-0.0664
N695 G0
N700 G1
N705 G0  X-0.0820  Z0.1000
N710  Z-1.0000
N715 G1
N720 G0
N725 G1
N730 G0
N735 G1  X-5.0305
N740 G0  Z0.1000
N745 G1  Z-1.0000
N750 G3  X-5.1250  I-2.5625  k-6277438562204192500000000000000000000000000000000000000000000000000.0000
N755 G0
N760 G1
Thanks, Chip
Post by: Brian Barker on May 07, 2007, 08:21:38 PM
Yup, that is junk data that you are getting for K...
I will see if I can find the problem
Brian
Post by: Brian Barker on May 07, 2007, 08:51:55 PM
problem has been found and i sent it to Art :) will be in the next rev
Brian
Post by: DennisF on May 08, 2007, 09:52:59 AM
Hi Guy's
In looking at LC i can't tell what version i am using it just say's 2.0 i know there have been upgrades to LC but what is the current version?
Rg's
Dennis
Post by: PaulWC on May 08, 2007, 11:51:41 AM
The currently available download is named "LazyCam2.00.exe", but it installs ver LazyCam2.00.2.
Paul, Central OR
Post by: DennisF on May 08, 2007, 01:55:13 PM
Hi Paul
 Thanks for the info, i see from the above post that you are using LC for a lathe i am new to Mach and LC not used anything like LC before and  i am trying to figure out how to  draw a profile in a cad program so LC can recognize an outside versus an inside turn i know you have to draw a line some how to designate this but i don't understand it can you give me any info on how this is done.
Thanks Rg's
Dennis
Post by: PaulWC on May 08, 2007, 02:37:29 PM
Hi Dennis,
Here's the thread on LC Turn setup. It's a little stale, but should get you going:
http://www.artsoftcontrols.com/forum/index.php?topic=2968.0
LC Turn is still getting some fixes by our Guru's, so give it a try and report your results. Lathe ops seem to be somewhere around 25% or less interest here, so we need all the supporting members we can round up. Fortunately, Art is the Big Gorilla in our corner.  ;)
Good luck, and let us know of any techniques you find to make LC Turn G-code work.
Paul, Central OR
Post by: Chip on May 08, 2007, 03:53:38 PM
Hi, All
Thanks for the post work in todays LC update, Art & Brian, Post is a little off I think but a nice step forward.
Seam's to post the Rough portion of code a little long on both end's.
Orientation for start of G-code & return to start point seem unclear/off.
What happened to the return to 0,0 in Post Option ?
Maybe there should be a Start at x,z & Return to X,Z in LC Lathe or Post option's, To allow for clearer setup ?
Thanks & just some Thought's Hear, Chip
Post by: DennisF on May 08, 2007, 08:35:24 PM
Hi Paul & Chip
Thanks for your input, i agree with Chip that the start position shold be at the center of the billit on the right hand side and all turns shoulod be from this point to the X + to the Z- for the cut's.
The turn should start from the right hand side of the billit and on the center line of the lathe and then make it's turn moves from right to left or from tail stock to chuck.
Right now with the profiles Art posted the zero point is on the left then goes to the right to start the cut.
Dennis
Post by: PaulWC on May 08, 2007, 09:21:54 PM
Hi Dennis,
I normally set 0,0 the way you mention. I use a 1/4" drill blank in the chuck to touch off X with a cigarette paper, then step in 0.126" and set X0. Then I mount the workpiece and touch off on the outer (right) end for Z0.
The only time I use the left end as Z0 is when I'm doing a facing cycle to bring stock to correct length. Then I touch off on the face of the chuck body.
I downloaded today's LC posting, and I still get tool profiles shifted to the left by the nose radius value. And still have the tool profile trying to go to X0 off the left end of the stock.
Patience will bring all good things with time!  ;)
Paul, Central OR
Post by: PaulWC on May 09, 2007, 12:52:43 PM
Hi Art,
Here's the dxf file I was using when trying the offsets.
Post by: PaulWC on May 09, 2007, 01:33:46 PM
Hi Art,
Here is a saved Project file with my settings.
By the way, the Forum won't allow uploads of *.Lcam files.
Thnks again, Paul
Post by: Chip on May 09, 2007, 02:11:18 PM
Hi, Art
Hears the DXF File that would load before recent changes in LC ver. 2.0.001.
It Hangs up LC during Load at Duplicate Entity Removal ...
LC Ver. 2.0.003 Has fixed The Move Origin Mouse Move Hear Also, Woooo---Hoooooooo.
Thanks !!, Chip
Post by: PaulWC on May 09, 2007, 02:59:59 PM
Hi Art,
Here's a new project file generated from the current LC download.
Thanks again, Paul
Post by: Chip on May 10, 2007, 12:26:39 AM
Hi, Art
Sorry about that File, Took a Coffee Brake to load for Me, But it Loaded.
There's a 3 x 4 inch object in there Some Where to cut, It's so small you can't see it at All, Just 2 dashed lines bottom Right of drawing.
I Didn't now it had some Turned Off Layer's, Hadn't loaded it in to a Cad Program.
File Was from a Friend's company that builds 37' & 47' Trawler's.
The Zoom Button feature zoomed into it Fine.
The double click on the Screed to re-size Fine Also
A couple Thought's Hear.
Could you Add a stasis Bar or % Done showing that LC is Still Active, And a way to Terminate Back to a stable LC if Such a File is Loaded by Mistake
Windows Task Monitor and the top of the LC Window will Show "Not Responding" even though LC is Plugging Along Just Fine.
Thanks, Chip
PS: The Move Origin with Mouse is Working  Wonderfully.
Post by: Chip on May 13, 2007, 11:39:58 PM
Hi Art & Brian
Working with Ver.2.0.005 LC
Layers as drawn is back & Working, Thanks
Optomiize drawing, Doesn't remove Redundant lines, As it did in previous version.
Remove Redundants on Load, Has never Removed them for me and still doesn't.
I see Splines are loading now, Thay cut a little funny, LC imports the shape to create them also.
The Move Origin with Mouse is Working Wonderfully, I have had it mess-up with Art's error Msg.'s a couple times, But not at first move of Origin as before, Ill go back and note them and post Soon !!.
Lathe: I must be Missing something hear (Everybody Nodding there Head's, L-O-L U-Hu..a...), OK!, Enough,!!.
Seem's to post the "Roughing" portion of code a little long on both end's
Orientation for start of G-code & return to start point seem's unclear.
Should be at end (Right End at stock OD, Rad. X & Z 0)
Maybe If reset Origin to min x, Z then Move Origin to set start point & move it away from profile to stock Dir, Rad., then generate Inc moves to fill/cut into final pass value would/could allow starting at left,Right or Center and use X0, Z0 Start point.
This would allow for Joging/Cutter Calibration and reset to 0,0 for start.
Thanks & Just some Thought's Hear, Chip
Post by: Chip on May 14, 2007, 01:44:32 AM
Hi, Art
LC Ver  2.0.5?, Latest ?
Getting UnRecov. Error Calling Text List Complete with Mouse Move of Origin.
LC ver 2.0.4 is working fine moving Origin, Optimize removes Duplicated Lines also..
Prev. Post
Thanks, Chip
Post by: W.Jansen on May 14, 2007, 05:56:33 AM
Hi Chip
With the origin i have the same problem as you do, in version 04 i can move the origin without errors but there is no tekst with it.
I have noticed this to Art and it seemes the tekst is the difficulty , he sould turn it on again and see whats happend.
I think he did and so it seemes the trouble is back again.
Greetings:
Willem
Post by: Brian Barker on May 14, 2007, 08:14:46 AM
The Remove redundant will get looked at and  we have a message out to the company that wrote the importing code about the splines :( We will have that in as soon as we get the fix :)
We are going to be doing a bunch of work to turn as soon as we have mill and plasma working :)
We are going to add MUCH more code to the turn section :) (Time is the problem at this point, and there are more people that use mill :( )
Thanks guys
Brian
Post by: W.Jansen on May 14, 2007, 09:23:09 AM
Thanks Brian
Sound promising, looking forward to this.
I think maybe you are right about more people use mill but watch until they find out that a latche is also a nice machine to play with.
Greetings:
Willem
Post by: PaulWC on May 14, 2007, 09:27:28 AM
Hi Art,
Here are the screen shots of my Offsets attemp.
Post by: ART on May 14, 2007, 10:11:02 AM
Paul:
 Two things.
 I just reran it here, and of course I get a perfect offset. :) , Id like you to check the value of the
Tolerance in the Extents tab in th elower status tabs. Mine is set to .0001 , can you set yours to that and
see what it does?
  If it still doesnt give an offet, save th eproject at that point, and send me the EVA.LCam file will you. It may give me a hiint as to why your not
getting th eoffet you should. I cant seem to duplicate it here..
Art
Post by: ART on May 14, 2007, 10:34:19 AM
Hi Guys:
  I have added text back in, but any errors should list a new text message as to where the erorr is. Id appreciate any notification of what it tels yu is the place of the crash so I can narrow it down
to what exactly is causing it. Then I can fix the error rather than just mask it.
Art
Post by: W.Jansen on May 14, 2007, 10:58:26 AM
Hi Art
As soon i hit the origin with the mouse a mesage is given: unrecoverable error in calling text lists complete notify artsoft attemd to continiu?  yes/no if i hit yes noting happens if i hit no the windows error report screen appears and the program closes.
Greetings:
Willem
Post by: PaulWC on May 14, 2007, 12:25:55 PM
Hi Art,
I changed the Connection Tol.: to 0.0001... still no offseting.
The saved LCam Project is attached.
Thanks, Paul
Post by: PaulWC on May 14, 2007, 01:32:15 PM
Hi Art,
Here's my LazyCam.xml file.
Thanks again, Paul
Post by: Chip on May 14, 2007, 01:34:28 PM
Hi, Art
Using LC ver 2.0.006 + Net 2.0
Unrecoverable error in calling text lists complete notify artsoft, With mouse move of Origin.
Chip
Post by: PaulWC on May 15, 2007, 06:09:11 AM
Hi Art,
Another thing happening here is a Debug Error shows up when closing LCam after trying the Offsets. It doesn't happen when closing LCam without doing any work.
Thanks agian, Paul
Post by: PaulWC on May 16, 2007, 01:34:16 PM
Hi Art,
Here are my current .dxf, .Lcam and .xml files I'm using with LazyCam Pro ver 2.01.
Thanks yet again for the continuing growth of this app.
Paul, Central OR
Post by: homecockpitbuilder on May 16, 2007, 01:50:39 PM
Hello,
Just get my licence key for lcam. Now i'm trying to load my file but the drawing is verry difrend than the old version of lcam.
I'm not getting strayt lines and the round corners are not right.
Screenshot i've send to see the problem.
regards Bas
(http://www.homecockpitbuilder.com/screenshot.JPG)
Post by: PaulWC on May 16, 2007, 03:50:51 PM
Hi Art,
Here is the new "clean" drawn outline that does not produce an Offset.
Post by: PaulWC on May 16, 2007, 08:05:39 PM
Hi Art & Brian,
Getting back to LCam Turn... using ver 2.0.1, I tried creating G-code. I modified the dxf so the profile extends beyond the right and left ends so the previous artifacts would be off the finished profile. I figured I would jusr edit the G-code to take out the paths on the ends.
However, there are other errant toolpaths that cut into the profile. The toolpath takes a straight line, rather than following the arc defined by the G2/G3 command. I haven't verified the I&K values yet, but suspect the locations are the issue. Sidenote... the "k" placed in the code is lower case, while other letters are caps.
Attached are my modified dxf, and the G-code generated.
Thanks guys, Paul, Central OR
Post by: PaulWC on May 16, 2007, 08:08:55 PM
Hi again...
Hit the Post before adding attachments... sorry.
Paul
Post by: ART on May 16, 2007, 10:09:13 PM
Paul:
 LOL. You really do confuse me. This damn thing profiles here perfectly as well. No strange lines.. Im going to have to add some diagnostics to see whats up..
Art
Post by: PaulWC on May 17, 2007, 02:13:25 AM
Hi Art,
I'm even more confused... I installed Mach3 .65 and LazyCam 2.1 on another shop computer and LazyCam fails to start. The Application Error dialog says: The application failed to initialize properly (0xc150002). Click OK to terminate the application.
Repeated attempts to launch give the same result. I uninstalled both Mach3 and LazyCam, and emptied the Mach3 folder except for my license.dat's. Then did a fresh install of both apps... still no LazyCam launch. Mach3 runs fine.
IBM T23 ThinkPad, Pentium III, 1Ghz, 512MB, WinXP Pro SP2.
Post by: Graham Waterworth on May 17, 2007, 05:03:59 AM
Has the new install got .net on it?
Lcam needs it.
Graham.
Post by: PaulWC on May 17, 2007, 09:27:34 AM
Hi Graham,
You have inspired me to say.... Duhhhh!  ;D
That's what I get for trying something while running on vapors.
Thanks for the nudge in the right direction.
Paul, Central OR
Post by: PaulWC on May 17, 2007, 11:42:38 AM
Hi Art,
Here's the screenshot of my Offsets attempt, Along with the Turn profiles form the other computer.
Thanks, Paul
Post by: Brian Barker on May 17, 2007, 12:06:33 PM
Affter you offset press clean and see if that fixes the offset problem with the leadin. I think that will work...
Post by: PaulWC on May 17, 2007, 12:30:37 PM
Hi Brian,
No apparent change after clicking Clean, other than a redraw of the panels.
Another question... when creating an offset, how do you turn off toolpath for the original profile (OUTSIDE)?
Post by: PaulWC on May 17, 2007, 12:34:33 PM
Hi again Brian,
Never mind... I just deleted the OUTSIDE Layer and took care of that issue.
Thanks again, Paul, Central OR
Post by: PaulWC on May 17, 2007, 12:37:02 PM
Hi once again Brian,
I moved the leadin point and voila!... the leadin appeared.  :)
Post by: Brian Barker on May 17, 2007, 08:54:28 PM
Cool :) I think I have found a small bug in that code ... it should help (I hope)
Post by: PaulWC on May 18, 2007, 12:16:57 AM
Hi Brian,
Here's a list of all the junk I have running on my main shop computer. It hasn't interfered with Mach3, but maybe there's something in there stepping on LazyCam's Offset function. Let me know if anything in there strikes a chord.
Post by: docltf on May 26, 2007, 07:45:34 PM
mr brian
when i do a simple dxf with a circle that is centered,then when i rotate the drawing 5 degree or more the circle gets
lost.if the dxf has the circle on a offset when i rotate on a 90 the circle is still visable.using another degree like 32 no circle.
thanks for taking a look.
bill
Post by: Brian Barker on May 27, 2007, 12:23:34 PM
Please Post the DXF and i will have a look at it ...
Are you talking about rotating the view or the drawing?
Post by: docltf on May 27, 2007, 01:09:00 PM
Mr brian
when i rotate the drawing.file attached
thanks bill
Post by: askman on May 28, 2007, 08:18:35 PM
Hi brian.  I've been using the lazycam pro (got the ugrade)  and so far so good.  I do have a question on pocketting.
I have a  smaller shape inside a larger shape and want to pocket between the two shape.    I don't think it is possible to do it in the version I have.  can it be done?  if not,  can you add the functionality?  that would be really cool.  I realize this can become quite complicated, but I think it would be be great function
thanks.
Post by: Brian Barker on May 28, 2007, 09:35:06 PM
Docltf
I have found the problem and is fixed for the next rev
Brian
Post by: Brian Barker on May 28, 2007, 09:36:38 PM
AskMan
Lcam  should do that now...  you select the outer chain and tell it to pocket and you are done :)
Post by: docltf on June 01, 2007, 12:14:35 PM
MR Brian
this has to do with after creating a offset,when using a circle.i was playing with offsets using a
circle,after creating a inside or outside offset,when leaving the check box unchecked for direction of cut then creat
offset when you try to highlight the new chain it wont highlight.if you do this to a rectangle it works right.
thanks bill
Post by: Brian Barker on June 01, 2007, 04:29:04 PM
Art and I should have out the fix in a few days (I hope) I have been working on the code and working on a few other projects that I had to get done...
But I think it is time to work a bit more over the weekend to get this finished for release!
Brian
Post by: docltf on June 01, 2007, 08:09:59 PM
MR Brian
you and art are really doing a super job,made me a true recuit.i enjoy playing with the new lcam.BTW how many
keyboards do you burn up a year.if i run into something else i will bring it to your attention.so far the little items
that i have noticed has not hurt my work any.i also know you need info.thanks for the product.
bill
Post by: Brian Barker on June 01, 2007, 09:47:16 PM
It is not to bad :)
We just work everyday and try to keep working on the bugs... The model that we use is not the normal "develop in house and show it when it is finished and fully tested". We like to have people tell us what they think as we are working on the software and we also think that it makes for a better product in the end (Thanks to all the help of every one on the forum and the group).
I hope to have a new rev out for you very soon :)
Brian
Post by: docltf on June 02, 2007, 12:14:31 PM
MR Brian
you don't have to post a response to this.downloaded lc2.05 today.i like the way the indavidual chains rotate will be
looking forward to rotating the whole drawing as the future realeases come out.when doing offsets on a rectangle
using any combination (in,out,cw,ccw) it's good.when doing offsets on a circle with differant combos it has trouble.
looking forward to the next version.
thanks bill
Post by: Brian Barker on June 02, 2007, 07:54:39 PM
You should be able to rotate the drawing if the check the rotate drawing button :)
Post by: docltf on June 03, 2007, 08:49:53 AM
MR Brian
you got me fair and square,i did not notice the new options in the rotate box,pretty goog stuff.you would think
that after trying many selections that i would see it.it would have taken me two weeks to notice it.
thanks bill
Post by: Brian Barker on June 03, 2007, 12:19:10 PM
No trouble :) I was thinking that it was not working ... so it is good news all the way around  ;D
Post by: wnevels on June 15, 2007, 02:14:13 PM
ya know what drives me nuts doing a metric project in lcam using inch tools
Wes
Post by: vmax549 on June 18, 2007, 04:27:33 PM
Gen Notes:
USing V.076 I cannot access the different layers by clicking on them from the screen they highlight but do not change. I can change the layers from the properties bar ok
Multipass, do we really need to return to and from safe z on each pass?
Leadin? What is the proper size for a lead in? Is it a ratio of the tool diameter? Can we have the default based on a ratio of the tool diam?
Tool table, can we have a reference popup window that accesses Mach's tool table for a reference(this is LAZYCAM correct I get too lazy to go find the tool table catalog for mach(;-) )
Drill holes, If in the tool settings it calls for a step that is less than the max depth can we have a peck drill instead of a straight drill.
           COuld we have an option to create another layer of the drill layer to use for a tapping layer, with the input to set up mach for
           tapping Gcode wise(G95,Feed per rev,Etc., or a spot drill layer , etc.
Good so far (;-) TP
Gcode utility, could we have a simple utility to reoder the line numbers that get mixed up from cutting a pasting and editing the Gcode file.
Post by: wnevels on June 18, 2007, 10:19:40 PM
Art or anybody
how do you fix this heart so it will import into lcam.
Wes
Post by: Chip on June 18, 2007, 10:29:44 PM
Hi Wes
Give these a try loaded into TurboCad 8, Grouped All.
Last Dxf as Drawn by you. Fine after loading in TC and Saving.
Hope this Helps, Chip
Post by: Kryten on July 26, 2007, 08:58:22 AM
Hi Guys, I used an example DXF for Lazycam Turn and came up with the attached toolpath in Mach 3. It doesn't seem to cut the spirals but Mach 3 Turn always displays them. Mach 3 version R2.3, Radius Mode, Reversed Arcs in Front Post unchecked,Lazycam 2.02 downloaded July 26, 2007. Diameter mode would be much appreciated. Thanks, Glen.
Post by: Kryten on October 16, 2007, 02:02:17 PM
Hi group, is there any chance of diameter mode becoming available in LazyCam for lathe ?
Thanks, Glen.
Post by: docltf on November 18, 2007, 09:47:46 AM
will there be a import feature for a tap or a text file with out mach3 running in the next release of l-cam.
thanks bill
Post by: XavierZ on November 22, 2007, 09:06:38 AM
Your video demonstrates the cam can generate g-code to write text on a plane. Is there any way to write text on a wheel with CNC milling machine? Thanks, Xavier
Post by: stevero on January 24, 2008, 09:04:01 AM
Hi, I am new to cnc. Purchased a small 21X12X3 hobby mach om ebay and Mach3.
I do a lot of scroll sawing and was wondering, will LC pro handle my scroll saw plans that I scan into Designcad and save as R12 DXF file? Or should I buy a higher end cam package?
Thanks formn a novice.
Steve in WV
Post by: Chip on January 24, 2008, 01:13:43 PM
Hi, Steve
LC should work fine, The Pro ver. adds Offset's, Pocketing and Turn Features.
Thanks, Chip
Post by: Fab6657 on August 16, 2008, 02:32:43 AM
Morning,
i have problems with the actual version of LazyCam 3, the mill compensation
doesnt run correctly by me !
i downloaded a older version (2.02) and the compensation work mutch better.
Do you have an idee, bug, bad usage of me ?
Fabrice
______________________________________________________
News : i found one reason : no right tool im Mach3 ! now run better.
Title: HOW TO ADDING G28 CODE ON LAZYCAM?
Post by: wakedabed on November 12, 2014, 09:51:47 AM
Please to help me!
i just want to know how i can make the lazycam adding RETURN TO HOME POSITION after finished the project!
