Mach Discussion => Brains Development => Topic started by: Ankit Mistry on September 16, 2015, 04:29:59 PM
Hello All members,
This is my first post in our forum. so basically what made me start this thread is using of Formula in Mach3
i learned and solved equations for Scara arm and many trigo formulas for test. so at this time i tested one Z axis Compensation formula in which There is Rotary B axis in head, which needed value of tool height, so as shown in formula dialogue box i put T letter in length offset, but t is not working anyhow. don't know why but even if i put 1 in t value and put function in any axis like F(A) =T result shows 0 always whenever i try to include T letter in Formula it shows 0 no matter how actual result should be but it fails to calculate estimated results and always end up with 0. any one can throw some light how to use T in this formula ???
Here is screenshot of formula i tried and test results as well in respective box.
Ankit
Did you activate the TOOL # It only sees the Current Tool (active one) not the selected tool .
Thanks BR549,
but it must not result in 0 anyhow no matter if i have tool or not... and i tried changing Tool with DRO, let me try with M6.
No use of t even after changing tool by M6 !
I played with it for a few minutes yesterday, and it didn't work here either.
is there any script ?? where this formula stuff is located in mach folder ??
cant we customize it ??
Well IF you are a brave soul you could write a Plugin to do what you want.
how to write plugin ???
Any sample plugin guide ???
I think my first port of call would be; FTP Downloads / Docs / Plugin Bible.pdf http://www.machsupport.com/software/downloads-updates/
