Mach Discussion => General Mach Discussion => Topic started by: akfalar on May 02, 2007, 03:11:54 PM
Title: "SmartPath" or Waterjet Speed ramping based on geometry question??
Post by: akfalar on May 02, 2007, 03:11:54 PM
It looks like Mach will do this but could someone verify: can Mach 3 do waterjet ramping based on geometry?
Thanks so much,
AKFALAR
Title: Re: "SmartPath" or Waterjet Speed ramping based on geometry question??
Post by: Graham Waterworth on May 02, 2007, 03:41:05 PM
There is no set function for doing this, but it can be done with the accel/decel, by setting this to ramp up and down at a slow rate it is possible.
Graham.
Post by: akfalar on May 02, 2007, 07:21:52 PM
Our current CAMsoft setup looks ahead for corners or circles of a tight diameter and based on the angular criteria it slows to accomodate.  I saw someone else talking about look ahead functionality.  Could you elaborate on this?
Thank you very much,
AKFALAR
Post by: Brian Barker on May 02, 2007, 10:27:43 PM
We do that in the LazyCam for Plasma in circles ... and we could add it for small Arcs.
You could add that to the Galil plugin if you like...
