Mach Discussion => General Mach Discussion => Topic started by: Davek0974 on August 23, 2015, 08:37:15 AM
Title: DRO's do not always zero?
Post by: Davek0974 on August 23, 2015, 08:37:15 AM
I am setting up a new plasma table and find that when referencing, the DRO's do not always zero after.
Usually works but not always???
I am referencing X normally (DoButton ( 22 ) i think ) but Y is slaved and I'm using RefCombination ( 10 ) in the ref button script.
Any thoughts?
Title: Re: DRO's do not always zero?
Post by: ger21 on August 23, 2015, 08:55:30 AM
Check "Auto Zero" in Config > Homing/Limits
Post by: Davek0974 on August 23, 2015, 09:01:22 AM
Apologies, should have said that, yes it's checked.
Post by: ger21 on August 23, 2015, 09:59:08 AM
If you have offsets set, the DRO's will display the offset, as homing zeroes the machine coordinates, not necessarily the DRO's.
Post by: Davek0974 on August 23, 2015, 10:04:17 AM
Ah, that might be it, will check tomorrow, thanks
