Mach Discussion => General Mach Discussion => Topic started by: mjalaly on August 18, 2015, 11:29:12 AM
So after years of having this issue, i think i have found the problem. So what is happening is that every time i go to jog, it is running super slow no matter how i change things. I think what is happening is that Mach 3 is not dropping the last feed rate from the previous drill cycle. Has any one had this issue? Any way to flush the feed rate at the end of a program?
Here is the previous discussion about it.
https://www.machsupport.com/forum/index.php/topic,24289.msg172135.html#msg172135
