Mach Discussion => General Mach Discussion => Topic started by: rpicinic on August 15, 2015, 03:31:22 PM
I just can't seem to synchronize the rpm of the spindle in mach3
I have a spindle tach (simple hall effect sensor circuit) setup correctly as it reads the spindle fairly accurately.
checked it with a laser tach
I have a CNC4PC C6 board working great as it varies the speeds as it's supposed to
tried everything i could;
form the values in the motor tuning
have some settings in the motor tuning that makes the RPM match accurately at top speed.
half way down it is off about 25%
at the lowest speed it is off 70%
Max RPM 3600 (after warm up)
half speed 1800 rpm set .... actual is 1325 rpm
1000 rpm set ..... actual is 300 rpm
so far this is the best i could get it set to.
any help is greatly appreciated
thanks
PS> please don't suggest the "Calibrate Spindle" ...... doesn't work at all for me.
It messes things up each time. I actually have to delete the "Linearity.dat" file each time to reset it to normal.
This was written long ago by the person who WROTE MACH3
Hi Guys:
This proceedure is not in the Doc's, the reason being its likely to change at some point. What I really
woudl liek to know i show linear YOUR system is using this as the speed setting for it. The setitngs are
highly misunderstood, and many run a linearity run when it isnt necessary, and it badly affects their results.
VFD:
A VFD takes an output from Mach3 to control its speed. Initially, Mach3 supposes a 1:1 linearty of the result,
which is pretty close to most vfd's in reality, they have allot of electronics in them to do this on their own. BUT
if the output is not right or not linear as output , then the result is obviously goign to be off. So the
following steps will do it right, and Id be very interested in any posts of the results.
Step 1)
Delete the linearity.dat file in your mach3 installation. The system will recreate it on next startup with 1:1
as the table. Also set the config/pulleys to pulley number 1, with a max speed of 1000, and a min speed of 0.
This means the range of commandis now S0 to S1000. ( Doesnt matter what the real speed of your spindle is, use
these numbers to start with.
Step 2)
We now need to know the max speed of the VFD's input, this is the place most get it wrong. VFDs respond,
as do frequency/analogue convertors to only a specific range typically of input vs output. SO lets figure out the top
speed expectation of a VFD..
In config/motor tuning, set the spindle axis steps/unit to 60. This means the velocity slider will now display in hz..
What we need to find out here is both the max frequency of the spindle and the clip frequency of the VFD.
To do this we now set the velocity slider to max. Youll notice it now reads the kernal frequency your using. 25000
in 25Khz for example. Apply the settings and exit the dialog.
- Turn on the spindle and set a S1000 as the speed. Measure the true spindle speed.
- Set a Speed of S950.. then S900, then S850..etc until the spindle actually slows. What will
happen on many systems is you will still get maximum speed until you lower the speed to some number..say S750..
or it may happen that the speed instantly start to slow slightly at S950..
Whenever it occurs that the spindle starts to run slower, note the S speed just prior to the slowdown.
For example, at S1000 I get a true RPM of 3000. SO the following occurs as I do the series..
S1000 -- 3324RPM
S950 --- 3324 RPM
S900 -- 3324 RPM
S850 -- 3156 RPM
SO the magic number here is S900, the last value where the spindle was at max RPM.
This shows us that using 90% of the max frequency tells the VFD to go full out.
So in motor tuning, set the velocity slider down to 90% of the max setting or current setting in Hz. ( Speed / 10 in % ).
Step 3)
Command a S1000 again, the max speed should still result. ( For higher accuracy and linearity you can repeat step 2
and vary the velocity slider to the % of the current slider position if you wish, the more you do step 2, the less change you
shoudl have to make each time. For example if it was at 21600 at this point , another run through step 2 might make you change it
to 21250.. each time the change will be less and less. )
Note the current S1000 speed and enter it in the config/pulleys as the max speed, leave the min speed to 0.
Step 4)
Turn on the spindle and seta speed of S1 . Note the speed you get and eneter it in the config/pulleys as minimum speed
for that pulley.
OK, so now we have properly set the VFD clip frequency, and the pulley min and max values. They now take into accoutn the expectation
of the VFD, and the resultant speeds at low and high end to be expected. The linearity is now considered to be 1:1 for that VFD/freq->analogue conversion.
If you have done this, please post a report of the following run..
Take max speed and divide by 10. Say max speed in pulley max is 2500, so the increment will be 250. Post for me 10 speeds..
S1 actual RPM: ???
S250 ""
S500 ""
S750 ""
S1000 ""
..etc..
Using this proceedure takes allot fo the guesswork out of setting up a spindle, forces you to take into
account the VFD clipping limits, forces the setup to show you the outgoing frequency in hz of the output and should
show us a quantifiable spindle vs command relationship as a result.
Take note, this is for step output spindles, PWM is another matter, this will still work, but since the number of steps
in speed is dependent on the PWM settings, the end results may be off in a stepwie fashion if using PWM.
Non-linearity can coem from several directions, frequency->analogue conversion can be way off a linear scale,
most vfd's will be pretty close to linear if clipping is taken into accoutn as above. For my part Id appreciate any feedback
on the speed test results after a fresh setup of spindle speed using the above proceedure. Some may find their max speed
is now higher using this technique, others will find a much more linear resultant spindle speed, it shoudlnt negatively affect
anyone if done right.
Thanks, and good luck..
Art
Thanks Art. I'll review and follow to give it a try.
Sent from my iPhone using Tapatalk
