Third party software and hardware support forums. => LazyTurn => Topic started by: Cam10000 on August 12, 2015, 07:11:20 PM
Need help. When i create a rough profile on lazy turn it seems to work perfectly but when i add the fine profile that profile looks correct in lazyturn but the code cuts about twice as deep on the x.
here is a picture of my file in mach3. any help would be appreciated
You appear to be mixing Dia. and Rad. modes.
You must do everything in the same mode.
See the instructions by RICH in the docs. section.
Russ
Thanks Russ,
dia mode vs rad mode.
Figured out my problem with help from Russ, but can't find in the manual how to fix this. I see how to turn diameter mode on and off but not how to turn it on/off between rough or fine cuts. When i uncheck diameter mode the program works fine but when in diameter mode the rough cut is correct but the fine cut is still in radius mode. is there a fix for this or do i just need to keep it in radius mode?
Thanks.
Look through this :
http://www.machsupport.com/forum/index.php/topic,20715.0.html
It might help.
Russ
Thanks again Russ.
Radius Mode it is. Everything is working fine.
