Third party software and hardware support forums. => SmoothStepper USB => Topic started by: discojon on August 03, 2015, 09:52:19 AM
Greetings,
I have a CNCRP PRO4848 with the HY VFD and Chinese 2.2kw spindle. I'll start by saying everything is currently working as intended with one exception. I am unable to attain the full 24000rpm / 400 hz when using software control.
Setup:
CRP PRO 4848
CRP500 prewired NEMA 27 electronics with ESS
HY VFD
Chinese 2.2k Spindle
Mach 3
Things I've Tried:
Base PWM frequency - had no effect
Spindle steps - no effect
change BoB - no effect
Under manual control from the VFD, I can achieve the full 24000rpm / 400 hz. However, under software control using Mach 3, only around 8.8 - 9.0 v is output from the breakout board when calling for full speed in Mach 3 corresponding to around 22000 rpm max. I have swapped BoB's with the hopes that would remedy the issue but it had no effect.
What settings do I need to verify / change, and where should I start troubleshooting? At this point, I'm out of ideas.
Thanks in advance
Discojon:
There's a fellow who posted a series of CNCRP videos on YouTube who worked through the same problem. His YouTube handle is "dirktheeng". His website is 21stcenturywoodworking.com. Hope this helps.
