Mach Discussion => VB and the development of wizards => Topic started by: MojsterMiha on August 03, 2015, 09:04:31 AM
Title: Wizard "Save as..." and "Load"
Post by: MojsterMiha on August 03, 2015, 09:04:31 AM
Hi
Is there a possibility to store the data entered in a wizard under different names in order to  be loaded  back later  and taken a small correction
(not only last entered data)?
I know that the G-code can be saved under different names, but if  later I want to change something I have to write  back all  the parameters in the wizard and generate G-code again.
G-code is probably not possible to convert back into wizard DROs...????
Example:
Load wizard - Circular Pocket
Enter all necessary data...
Save entered data As....
Generate G-code
Load some saved data into Wizard (not only last one)
Make  corrections...
Hope I was clear enough to get some advice... ;)
Title: Re: Wizard "Save as..." and "Load"
Post by: BR549 on August 03, 2015, 09:51:49 AM
Most wizards have an option to save settings so they are there when you return. Some do it automatically on save and return
Post by: MojsterMiha on August 03, 2015, 10:47:03 AM
Yes, Iknow that.
But it is possible to save not only last one?
For example:
I fill in data for pocket nr.1 and generate G-code
Day after I fill in data for pocket nr.2.....
Day three....I want to call back wizard with data "Pocket nr.1"
It's possible  something like this?
Post by: BR549 on August 03, 2015, 12:35:47 PM
Sure it is possible,  BUT you are going to have to rebuild and recode each wizard in order for it to do it (;-)
Post by: MojsterMiha on August 03, 2015, 11:39:22 PM
How I have to recode wizard? ???
I dont understand your suggestion.
Is there any command for save?
Where all data from wizard are saved?
