Tangent Corner => Tangent Corner => Topic started by: Overloaded on August 01, 2015, 09:50:46 PM
Title: PC Help
Post by: Overloaded on August 01, 2015, 09:50:46 PM
Hello folks, I could use some advice on fixing my desk pc.
It has somehow gotten infestered with some sort of ***ware that plugs in little popup boxes all over the text on this forum topics.
Really slows me down too.
I left my pc on and connected overnight and now have this mess. >:(
Anyone know a proven way to fix it ?
Thanks if you can help,
Russ
Title: Re: PC Help
Post by: BR549 on August 01, 2015, 11:06:49 PM
RUss you have a walware attatck  can you back up to an earlier waypoint  in windows. Then run a good antimalware software to remove it. OR you may have a look at your installs/ipdates record and delete anything loaded in say the last week or 2. They may have very familar and officail sounding names. Just delete them 1 at a time until the problem dissapears.
Just a thought(;-) TP
Title: Re: PC Help
Post by: Overloaded on August 02, 2015, 05:30:33 AM
Hi TP,
  where do I find the "installs/update record" ?
I did run a windows scan which took over 5 hrs, found a couple trojans, removed them but no fix on the mess mentioned.
Also, do you know of a "good" malware remover SW ? ?
Title: Re: PC Help
Post by: Rkjohn on August 02, 2015, 09:43:23 AM
This works better then any I have used for this kind of problem.
Spy Humter
http://www.enigmasoftware.com/products/spyhunter/
Title: Re: PC Help
Post by: BR549 on August 02, 2015, 01:44:08 PM
Russ go to the Control panel then uninstall /change programs. Sort the list by install date. Delete anything YOU did NOT install.  ONCE you get it back up THEN create a restore point So that in the future if it happens again you can simply restore back to a known waypoint.
Just a thought, (;-) TP
Title: Re: PC Help
Post by: Overloaded on August 08, 2015, 11:28:15 AM
Hey TP,
nothing shows up there. also tried a restore to last month ... no fixie.
The SpyHunter seems to have worked, found a bunch of junk.
Just hope it didn't load a bunch of it's own.
Much better .... for now.
Thanks guys,
Russ
Title: Re: PC Help
Post by: Rkjohn on August 08, 2015, 11:43:49 AM
Go to internet options & disable downloads in security folder. That will help stoping some of the crap coming in.
