Mach Discussion => Mach3 under Vista => Topic started by: Crattle91 on July 26, 2015, 07:41:37 PM
Title: Z axis running in reverse
Post by: Crattle91 on July 26, 2015, 07:41:37 PM
Need some help if you please. I am attempting to run my first project on Mach 3 and when my router begins to run it slams into my table. (Good thing I have a spoil board) I have narrowed the issue down to the Z axis being programmed in reverse but am unsure how to correct it.
 Help please...
Title: Re: Z axis running in reverse
Post by: Tweakie.CNC on July 27, 2015, 02:44:47 AM
If you have your machine Z axis direction wrongly set then...
Config / Ports & Pins / Motor Outputs - change the 'Dir Low Active' state for your Z axis (cross or tick) then click Apply.
That will change the Z axis direction.
