Mach Discussion => General Mach Discussion => Topic started by: Billm3wbh on July 12, 2015, 04:25:12 AM
Title: X axis reversed
Post by: Billm3wbh on July 12, 2015, 04:25:12 AM
Hi firstly I am totally new to cnc
I have setup mach3 in demo mode and all the axis move in the correct directions via the comp keyboard but when I press tab and call out the jog controls the x-axis moves the wrong direction
If I reverse the direction in the limits page all that does is now the axis moves correct on the jog controls but reversed on the keyboard
The same thing happens if I change the direction in the ports and pins page.
So has anyone got any suggestions as how to cure this.
Many thanks
Bill
Title: Re: X axis reversed
Post by: Tweakie.CNC on July 12, 2015, 06:13:12 AM
Hi Bill,
I am not sure you are getting this right because...
Direction relates to how the cutter moves with regard to the work rather than the travel of the machine parts (if I could explain this better then I would).
However, to overcome the particular problem that you mention then you could try reversing the keyboard assignments for the X axis in Config / System Hotkeys.
Post by: Billm3wbh on July 12, 2015, 06:45:30 AM
Hi Tweakie that is what I have done
Before I reversed it in the homing page I did a test run on a small disc without cutter using bottom left as the start it went to the left instead of the right but after reversing it was ok.
Bill
Post by: Tweakie.CNC on July 12, 2015, 07:13:56 AM
Great stuff Bill, I am pleased you have got it sorted.
Post by: Denford Miracle on December 10, 2015, 02:53:31 PM
how do you change the system hotkeys?   when I go there they cant be changed.
doesn't make sense.
Post by: Fastest1 on December 10, 2015, 09:34:57 PM
Why can't they be changed? Just click on whichever axis direction you want to assign a key to, then hit the key you want to use and hit enter. Hot keys should be on the drop down config box.
Sent from my iPhone using Tapatalk
