Mach Discussion => Mach4 General Discussion => Topic started by: amnon on July 04, 2015, 12:01:12 PM
Hej,
Why is that, when program runs with M3(spindle on), after a few minutes Mach suddenly stop and Reset button is red. It doesn't happen when spindle is off. Is it cause by line interference?
Best Regards
Amnon
If you have a VFD driven spindle or a spindle motor with brushes, the chances
are good that there is enough electrical interference to cause the problems
that you are seeing.
I've instaled interference eliminator, but still nothing. Kress stop all the time when start cutting. What can I do more?
May Relay have something to say, I mean if is not big enough?
Respect
Amnon
Tell us more about your system, what version of Mach, what hardware interface?
Where did you install the filter?
What message is in the status line at the bottom of the screen when Mach stops?
Done - additional filter
Thank's
