Mach Discussion => Mach4 General Discussion => Topic started by: Screwie Louie on June 30, 2015, 02:11:50 AM
Title: MDI input (Abs & Inc) through DRO to move axis....a working example
Post by: Screwie Louie on June 30, 2015, 02:11:50 AM
This is in response to a request by Pedio. He would like to input a number value into a DRO and have the axis jog to that position instead of going to the MDI input page, writing the block and pressing Cycle Start. I believe his intent is to maximize time efficiency by jogging to a known position from his home page. ie "Enter value, press enter" => axis jogs to desired position. This example is simple without error checking or safety checking (ie. rc values, is axis homed, or is Z axis clear before movement, etc) To implement direct input into a DRO as a text box I will do my best to describe the instructions below. By the way, this was a great idea! Thanx Pedio (If you don't mind, I would like to add this feature to my Blackout Screenset --which is open code for everyone to use, edit, play, add their own features, repost, etc....) You guys are gonna be like "That's it?!?!?" Yep, gotta love m4! I demonstrate a mc.mcCntlMdiExecute function to jog to an absolute coordinate position (G90) and then using mc.mcJogIncStart function call instead of mc.mcCntlMdiExecute G91 command. Hope this helps!
Absolute Position:[/color]
1. Operator -> Edit Screen
2. Add DRO --to wherever you would like for this MDI input to be
3. DRO properties are: DRO Code = Blank, Editor = Keypad
4. On Modify Script =
           local gCode = ""
           local Xmove = scr.GetProperty('droXMdiAbs', 'Value')
           Xmove = tonumber(Xmove)
           if Xmove == nil then Xmove = '0' end
           gCode = gCode ..string.format("G0 G90 X%.3f\n", Xmove)
           mc.mcCntlMdiExecute (inst, gCode)
Incremental Movement:[/color][/color]
           local Xmove = scr.GetProperty('droXMdiInc', 'Value')
           if Xmove == nil then Xmove = 0 end
           mc.mcJogIncStart (inst, 0, Xmove)
[/color]
That's it folks! I'll post some screen shots below in the next post to help you guys visualize the concept. It's pretty cool. Pedio had a great time-saving idea.
--josh
Title: Re: MDI input (Abs & Inc) through DRO to move axis....a working example
Post by: dude1 on June 30, 2015, 02:29:11 AM
well dude your hired you can start Monday
Post by: Screwie Louie on June 30, 2015, 03:01:13 AM
hold on a sec...I need to work on the increment DRO (I am using both the absolute and increment  coordinates G90/G91 at the same time...let me work this through)
I think I double posted...can a moderator delete the repeat post please?
Dude, this is soooo gonna work!
What's up Pedio? I sware you meant Pedro but Pedio? I think of PedioBear....lol! just kidding. Don't kick my ass...
Post by: machiner on June 30, 2015, 07:47:01 AM
very nice, but  i have one question
 what do the [/color]  and [/color] [/color] functions do ?
Post by: Overloaded on June 30, 2015, 10:07:25 AM
They are just from the forum when selecting a font color.
They are usually invisible but somehow got doubled up and pasted in this time.
Russ
Post by: Screwie Louie on June 30, 2015, 10:57:45 AM
Sorry Pedio...sometimes I have a little whiskey, open my mouth and insert my foot.
Post by: Pedio on June 30, 2015, 12:41:16 PM
Louie - No problem with the free use of the idea. I like having people innovate around M4. It can only help all of us!
I intend to use this to move the head out of the way when I load work pieces and to move it to fixed fixturing locations on the table (I have a 7'X10' table it takes a good deal of time to move the head around when loading different size pieces. It will be great to say move X=48 to load the pieces. I also like to park the head for different functions (change tool, etc). Often it depends on where I will be working around the table.
My name is Peter and Pedio is an derivative of Fabio. When I was at career day at High School the guidance councilor never even mentioned the career choice of "Romance Novel Cover Model". I would have soooooooo gone for that one!  (It is even funnier if you meet me in person)
Is the code posted above ready for test by newbies like me?
Post by: Pedio on June 30, 2015, 12:48:39 PM
Louie - just to be double sure. The absolute is the distance from the machine 0 and the incremental is from the current location of the head on the table?
Also, the way I am reading it is that the script for absolute is to move the X axis. If I want to make another DRO for the Y axis I replace "X" with "Y" in the script. Is that correct?
Thanks for this - it will make my life much easier.
Finally, where do I find the Blackout Screenset? I would like to take a look.
Post by: Pedio on June 30, 2015, 12:57:31 PM
Found the screen set below. Looks cool.
Post by: Screwie Louie on June 30, 2015, 01:14:23 PM
Yep! You're getting it.
The absolute distance is from work coordinate position 0.0
To utilize this script in machine coordinates you would use the G53 command; something like :
     gCode = gCode ..string.format("G0 G90 G53 X%.3f\n", Xmove)
Be careful just replacing X with Y. You are right in a sense but notice in this function:
"0" is the X axis identifier for mach4, as you set it up in your config.
You would change the function to:
     mc.mcJogIncStart (inst, 1, Ymove)
"1" is the Y axis identifier.
Post by: Screwie Louie on June 30, 2015, 11:12:30 PM
I would just use G91 for an increment move. I'll post a screen shot soon with the screen set. I kinda want to have only one DRO input with the option for:
a. Work Coordinates      Default movement from user's G54 offset
b. Machine Coordinates  G53
c. Absolute jog              G90
d. Increment jog           G91
e. Axis selection             X, Y, Z, A
or just 3 basic DRO inputs for X, Y, Z axes....idk
Post by: Pedio on July 02, 2015, 08:27:23 PM
Louie,
I tried to implement your DRO box this evening. I think I am doing everything right but the machine is not moving. I have attached screen shots of the DRO setup and the code. I am very new to Lua so I am not sure if I am inadvertently doing something wrong.
Post by: dude1 on July 02, 2015, 08:48:56 PM
it`s name needs to be the same as the scr.GetProperty
Post by: Screwie Louie on July 02, 2015, 09:08:22 PM
Here is the screenshot and the screen set with the embedded code. Add, modify, delete, PLAY :)
Still working through G53 incremental commands. Mach4 doesn't allow G00 G91 G53 move. "Cannot execute G53 incremental". I'll figure a way.
All moves are G00. If you want a G01 option, just let me know.
--josh
Post by: dude1 on July 02, 2015, 09:16:55 PM
to find what G is working  type it in to the MDI
Post by: Pedio on July 03, 2015, 07:25:33 PM
Yea Success!!!!!
I now can send X or Y flying all over the place. Thanks Louie
One other question -- what does the Hidden box do? I tried to make a home button and place it over the LED on the main screen. That way the axis would home when you clicked on the red LED. I thought it would be easy as placing a button over the LED, hiding the button and then demoting the LED to level 1 to place it behind the LED. It did not work. I resorted to a small button on the top.
Post by: Screwie Louie on July 03, 2015, 08:19:10 PM
just delete the LED and replace it with a toggle button. Toggle buttons have a lot of features that you may want.
Post by: dude1 on July 03, 2015, 08:35:08 PM
you can set toggle buttons to do stuff on up and down click, change color, different wording, flash they are quite fun to play with you could have I am not homed, then have I am homed anything really.
but you wont to keep it as simple as possible if there is a function built in to the button or what ever use that save`s have to use code.
Post by: Pedio on July 04, 2015, 10:43:40 AM
Louie - I tried this but the toggle button did not know when the other toggle button was depressed. Remember I was trying to do this to change between continuous and incremental steps on the Jog. If the machine was on continuous and I pressed incremental the other button did not know what was happening and would continue to appear like it was on. Perhaps it is best to look at what I was trying to do (see attached).
I am remedial and need REALLY big buttons to do common tasks or emergency tasks (like stop the machine).
Post by: Screwie Louie on July 05, 2015, 09:17:28 AM
the easiest way is to set the button state to 0 "of the opposite button" when the selected toggle button is pressed by using scr.SetProperty calls.
examples are in the screenset code I posted. -> click on the MdiDro, On Modify Script.
