Mach Discussion => Mach Screens => Topic started by: mike^3 on June 29, 2015, 12:56:15 PM
hello everyone, I have Mach 3 lathe, and I am trying to run the tool changer as the A axis, yet I can't get it to work in mach 3 lathe, I can get it to work in mach 3 mill fine.
When I try to job the A axis in mach 3 lathe nothing happens, but if I try to job it kn mach 3 mI'll it's jobs fine.
Am I missing something?
I have the ports and pins the same, a axis is enabled it mach 3 lathe, I do not have a dro set up in the screen, or a tool change number set up yet but will work on that once it moves properly,
Any help would be appreciated!!
This is an older thread.
Did you find a solution?
I have a turret tool changer. I have no issue changing tools. Using the A axis.
Sent from my iPhone using Tapatalk
