Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: db1 on June 22, 2015, 04:22:05 PM
Title: Load Gcode file from vb.net
Post by: db1 on June 22, 2015, 04:22:05 PM
Hello all,
I created a simple vb.net application that generates a gcode file for some simple shapes. After the file is created the user can click a button that is used to load the gcode into mach3 (This is just for convenience for the user) but when the button is clicked vb throws the following error :
                An unhandled exception of type 'System.Exception' occurred in Microsoft.VisualBasic.dll
                Additional information: Cannot create ActiveX component
Can anyone help interpret and fix this error? I have done a few google searches and was able to find threads with the same problem but none of the ones I found were answered.
Thank you for any help!
Below is the vb.net code that I use:
        Dim mach As Mach4.IMach4
        Dim scriptObject As Mach4.IMyScriptObject
        mach = GetObject(, "Mach4.Document")      <------- This is the line the error happens at
        scriptObject = mach.GetScriptDispatch()
        scriptObject.LoadFile(Filename)
