Mach Discussion => General Mach Discussion => Topic started by: LerninCNC on June 21, 2015, 11:33:39 PM
Hi! I'm new to CNC and this forum. Been involved with manual machining my entire career (40+ years) but CNC has proven to be a new, and exciting, challenge. Now to my question. Why does the jog function randomly stop working? Pressing the Regen Toolpath, Rewind, Reset, and the Jog On/Off buttons sometimes gets jogging to work. There doesn't appear to be a particular button that gets the jog function back. Sometimes I have to restart Mach, or the computer. Could this be a noise issue or a configuration/setup problem.
on some pages jogging does not work and under certin conditions it wont work until you hit stop
I'm on the Program Run screen when jogging stops working.
Hi I am in the same situation as LerninCNC jog randomly stops working and the tab key the does nothing, I am stumped,
My problem was due to electrical noise. After rerouting control wires away from power supply cables my problem went away.
Will try moving wire, thanks
