Mach Discussion => Mach4 General Discussion => Topic started by: machiner on June 12, 2015, 08:03:00 AM
i started with the 'stock' mach4 mill
i put this line of code into the top of the startup screen load script just before the two functions
local x = mc.mcGetInstance();
wx.wxMessageBox('screen load instance was '..tostring(x))
it always 'pops up' 6 times, instance 0 to 5 . .
whats up with that ! ?
Currently, (even though not functional yet), Mach4 can run 6 instances.
So, perhaps it is looping through the 6 possible instances, even though only instance 0 is currently supported.
Scott
thanks again, man
