Mach Discussion => Mach4 General Discussion => Topic started by: poppabear on June 09, 2015, 11:35:13 PM
Title: wxLua MP-03 Pendant kit(Peter Homann), Wizard for Mach4, in progress...
Post by: poppabear on June 09, 2015, 11:35:13 PM
Well, trying to port over the plugin I did for Pete's MP-03 modbus pendant to a wxLua Wizard and screen integration for Mach4.
It can do:
MPG, Cycle Start, Estop, FSOVR, Spindle On/Off via buttons, and
27 control functions via Soft buttons, that the user can custom assign,
Plus fire off 15 macros (user or OEM), and optionally map inputs to screenset "Leds" for monitoring or other purposes.
see screen shots of wxLua Pendant config notebook.
Scott
Title: Re: wxLua MP-03 Pendant kit(Peter Homann), Wizard for Mach4, in progress...
Post by: dude1 on June 10, 2015, 12:59:05 AM
well everyone else needs to catch up or higher you to do it for them
Post by: Chaoticone on June 10, 2015, 05:31:01 AM
Looking good Scott, looking good!
Post by: poppabear on June 11, 2015, 07:10:29 AM
Thanks Gents!
Made a minor mod, added text so that the user would know to only
use the Macro's Number part only for firing off macros.
Scott
Post by: Chaoticone on June 11, 2015, 09:06:37 AM
The devil is in the details for sure. It makes a lot of sense to add that little bit of instruction where you did and it looks clean. If you want it to really be seen make it stand a little more. Maybe use red text?
Post by: poppabear on June 11, 2015, 10:55:08 AM
Ok, that makes sense, and THANK YOU for the input!!
Scott
