Mach Discussion => Mach4 General Discussion => Topic started by: Screwie Louie on June 05, 2015, 12:17:25 PM
Title: v2336 Keyboard Simulator plugin
Post by: Screwie Louie on June 05, 2015, 12:17:25 PM
...the working one
Attached is the keyboard simulator plugin from m4 ver. 2336.
Just delete the keyboard sim from your plugin folder and paste this one in. It works like a charm. I have 30 inputs mapped to functions.
Below is some sample code to put into your signal table/library in the screen load up script. You can map keys straight from m4 input tabs under configuration for jogging. You can really do a lot with it.
I would recommend when you map a key to have the Caps Lock on. This way when you type the keyboard sim doesn't interfere.
I can manipulate mach4 using the keyboard simulator with my Bluetooth keyboard away from the computer. It is also good to simulate probe inputs to test code with using the Mach4 Simulator plugin (as a motion controller sim).
--josh
Code: [Select]
--Keyboard Sim 'Return' w/Caps Lock on to enable Mach 4.
    sigLib[mc.ISIG_INPUT60] = function (state)
        local inst = mc.mcGetInstance ()
        local hSig = mc.mcSignalGetHandle (inst, mc.OSIG_MACHINE_ENABLED)
        local sigState = mc.mcSignalGetState (hSig)
        if state == 1 then
            if sigState == 0 then
            mc.mcSignalSetState (hSig, 1)
            elseif sigState == 1 then
            mc.mcSignalSetState (hSig, 0)
            end
        end
    end
    --Keyboard Sim 'C' w/Caps Lock on to center table.
    sigLib[mc.ISIG_INPUT61] = function (state)
        local gCode = ""
        if state == 1 then
            gCode = "G00 G90 X9.0 Y2.0 Z0.0 \n"
            mc.mcCntlMdiExecute (inst, gCode)
        end
    end
    --Keyboard Sim 'Esc' for Estop.
    sigLib[mc.ISIG_INPUT62] = function (state)
        local rc = 0
        mc.mcCntlEStop (inst, 1)
    end
    --Keyboard Sim 'H' w/Caps Lock on to home all axes.
    sigLib[mc.ISIG_INPUT63] = function (state)
        if state == 1 then
            mc.mcAxisHomeAll (inst)
        end
Title: Re: v2336 Keyboard Simulator plugin
Post by: dude1 on June 05, 2015, 07:13:27 PM
well done
Post by: Screwie Louie on June 05, 2015, 11:06:49 PM
thanx Dan!
...here's the hot key package I got so far. still working on that auto tool sequence tho.
--josh
Code: [Select]
--Probe input.
    sigLib[mc.ISIG_INPUT0] = function (state)
        if state == 1 then
            mc.mcCntlCycleStop(inst)
            for i=1, myAxes do mc.mcMotorIsStill (inst, i)end
        end
    end
--Tool setter input
    sigLib[mc.ISIG_INPUT1] = function (state)
        if state == 1 then
            for i=0, myAxes do mc.mcJogVelocityStop (inst,i) end
        end
    end
--Keyboard Sim '2' w/Caps Lock on for auto tool zero sequence
    sigLib[mc.ISIG_INPUT58] = function (state)
        local hSig = mc.mcSignalGetHandle (inst, mc.OSIG_TOOL_CHANGE)
        if state == 1 then
                flag[1] = 1
                flag[1] = 0
            end
        end
    end
--Keyboard Sim '1' w/Caps Lock on for start tool setter calibration.
    sigLib[mc.ISIG_INPUT59] = function (state)
        local hSig = mc.mcSignalGetHandle (inst, mc.OSIG_OUTPUT30)
        if state == 1 then
                flag[1] = 1
                flag[1] = 0
            end
        end
    end
--Keyboard Sim 'F1' w/Caps Lock on to enable Mach 4.
        if state == 1 then
            mc.mcCntlEnable (inst, 1)
        end
    end
        local gCode = ""
        if state == 1 then
            gCode = "G00 G90 G53 Z0.0 \n"
            gCode = gCode .."G53 X9.0 Y2.0 \n"
        end
    end
        local rc = 0
        if state == 1 then
        end
    end
        if state == 1 then
        end
    end
Post by: dude1 on June 05, 2015, 11:30:44 PM
for the people who don`t know can you add where the codes you have posted goes, I know you have added it above but some people don't read instructions all the time
Post by: Screwie Louie on June 05, 2015, 11:40:56 PM
idk Dan...what do you mean?
one other thing though, 'myAxes' in the script is a my global variable of my total number of enabled axes. So wherever you see myAxes just replace it with 11 or whatever number you want....
Post by: dude1 on June 05, 2015, 11:46:48 PM
i am a bit dyslexic forgot to prof read before hitting post
