Mach Discussion => Mach4 General Discussion => Topic started by: TimGS on June 04, 2015, 03:40:23 PM
Just curious ...
Could the Input/output signals been setup with a Custom Signal Event Handler?
...It would dispense with the need for polling input signals.
sounds just as good as an 'Event_Macro_Hold"....whatcha talkin about willis?
Just Google "How to create an event handler in Lua"
so... who is the client and who is the server ...or... should I say....who is the
publisher....to the 'event handler'...to which, whom has subscribed to?
sorry, may be speaking greek....it's all TCP, lol.
fudge! I just realized I'm a nerd!!!!! NERDZ!!!! >:D computerized NERD control
lmao haha...ok, I'll quit now.
maybe.
Mach 4 would host the server since it is the core. Clients would sign up to receive/trigger events.
Modbus?
I was looking at the same typology kinda (publisher -> server -> subscriber) but having a signal from the mill be the publisher to a "channel" on a MQTT server and m4 being the subscriber (using a PLC script to ping the channel). That way I can control m4 from anywhere there is a Internet connection if I am away from the area. Well, theoretically anyway.
I know, your thinking, why go through an external server for signal processing when I can just send the signal straight to m4.....just trying to look a things from all directions. That's all. I'm really interested in learning more about TCP/IP config & comms with m4. I get where you are coming from. That's neat!
and will mr google be putting the stock on the machine.....
lmao! ha! point taken. ok, maybe not the best of projects to take on. shoot, that was funny ;D
it is a good idea if you use a tablet that gets updated info from the machine and you can kill it from a tablet and use it as a pendint. for when you go of to make a coffee, or other rest stop so when you get back to the machine you will know there is going to be no Decepticons waiting for you or a F machine
better answer would of been...."stock placement is automated". f those decepticons dan! ;D
well you could added a robot and pallet loader
You two are entertaining ;D
I just find crazy axe (Screwie Louie) funny I cant help but add something silly
