Mach Discussion => General Mach Discussion => Topic started by: AzzA2032 on June 02, 2015, 05:21:05 AM
Title: Mach 3 spindle setup problems
Post by: AzzA2032 on June 02, 2015, 05:21:05 AM
Hi There, I am trying to upgrade a lathe to a spindle with step/dir and cannot get anything to move, does anyone know if there are any hidden options or interlocks that might be stopping movement?
- If I swap Pulse output pins between my Z axis and spindle, then the servo for spindle moves and Z stepper does not, so wiring to servo and servo parameters seem fine.
- The spindle is set up in ports-pins/spindle, the output pins are setup in motor outputs, currently in motor tuning all numbers are the same as the Z axis since they give visible movement to the servo( although much higher and lower steps/unit have been tried)
- I have tried M3 S5000, the spindle button in manual mode and the up arrow in motor tuning(this works for the other axis), I have also tried setting up the Z axis(functions fine) step/dir pins to be a spindle and nothing responds to spindle commands.
mach3 turn
Smooth stepper ethernet/holmann designs breakout
Windows XP
Alan
Title: Re: Mach 3 spindle setup problems
Post by: RGBreton on December 05, 2015, 11:08:55 AM
Having same issue. Spindle setup works in the Mach 3 mill, copied the setting to Turn and can't seem to get it running.
Bob
Post by: Fastest1 on December 05, 2015, 12:08:03 PM
Turn seems to have a few issues. I am having some problems with Turn and the ESS.
Sent from my iPhone using Tapatalk
Post by: robertspark on December 05, 2015, 12:12:16 PM
Alan,
Can you post your XML file? (may need to call it something unique... like AzzA2032.xml to get it to upload.
Have you checked the step and direction option in the ESS config screen and setup the pulse width.
