G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: trucksavage on May 23, 2015, 11:47:10 AM
Title: Mach3 generating spurious loops in GCode
Post by: trucksavage on May 23, 2015, 11:47:10 AM
Hi all, I'm a Newbie but have managed to successfully produce a few pieces over the past week however, today I re-loaded a piece of GCode into Mach3 and it added a bunch of random purple loops, and it now seems to be doing the same to all my saved .tap files. If I load the same GCode into Mach3 on my design machine it seems fine, just when it loads on the PC that runs the CNC Router. (I have attached a screengrab and the GCode file if this helps). I have tried uninstalling and reinstalling Mach3 but the problem remains. Can anyone help?
Title: Re: Mach3 generating spurious loops in GCode
Post by: ger21 on May 23, 2015, 12:02:44 PM
Change you IJ mode in General Config.
Post by: trucksavage on May 23, 2015, 02:08:53 PM
Thanks for the reply, what is IJ mode and under which config heading is it? I'm not aware that I altered anything in the config?
